Soaron Hifi expert
Založený: 27 december 2015 Príspevky: 1923
Zaslal: So august 08, 2020 18:56:28 Predmet: DROP + GRACE DESIGN STANDARD DAC BALANCED |
Za štyri mesiace je doma. Je to krásna krabička, no určite by jej slušila aj strieborná farba.
odkaz: Drop - produktová stránka
odkaz: fotky
špecifikácia:
- Drop + Grace Design
- Anodized aluminum chassis
- USB bus-powered design
- If using SPDIF only, requires external USB charger - 5V, 1A wallwart (not supplied)
- AKM AK4452 DAC chip
- Latest-generation XMOS xCORE-200 USB processor
- 0.5% precision thin metal film resistors in the signal path
- No capacitors in the signal path
- Audiophile components and design throughout
- Coaxial connector for SPDIF (IEC-60958) audio input (transformer coupled and ground isolated)
- SPDIF input decoding and clock recovery is done with AKM 4117 input receiver
- Sample rates up to 192 kHz are supported
- USB 2.0/1.0 input type-B
- 3.5mm stereo line output jack (2.15VRMS)
- 3-pin XLR balanced line output(4.3VRMS)
- USB 1.0 connectivity: Driverless plug-and-play operation on Mac and Windows PCs, supports sample rates up to 96kHz with 24-bit precision
- USB Audio Class 2 operation via toggle switch: Driverless operation on Mac OS and Windows 10, supports sample rates up to 384 kHz and DSD256
- Dimensions, L x W x H: 3.9 x 4.1 x 1.2 in (100 x 104 x 30 mm)
- Height with rubber feet: 1.4 in (34 mm)
- Weight: 7.44 oz (210.8 g)
Sony WH-1000XM4 |
