allenlu Ready2Die
Založený: 10 september 2020 Príspevky: 1
Zaslal: Št september 10, 2020 04:43:51 Predmet: Advantages of extruded fish feed pellet for fish production |
1. Good palatability helps fending off feed substances isolating to make sure an even vitamins distribution in pellets to warranty a exact fish overall performance of feed intake.
2. Extruding procedure requires first-class particle measurement of uncooked materials, and at the identical time, extrusion gelatinizes the starch and denatures the protein, which contributes to excessive feed conversion and utilization rate.
3. Starch gelatinization and systematism heighten feed caking property so as to enhance feed water balance which can attain 12-36hrs. And higher water resistance capability higher vitamins retention and much less water pollution.
4. Some fishes want high-fat feed, the fats in extruded fish feed pellet has a excessive balance and an uniform permeation in pellets, making feed greater captivating to enlarge feed consumption of fishes.
5. Through the high-temperature and high-pressure process, many pathogens in substances are removed, so the digestive tract ailment is decreased correctly through extruded pellet fish feed.
6. Extruded fish feed can be made in one of a kind forms, such as floating feed, sinking feed, and slow-sinking feed, etc. to meet distinct fish farming methods, limit feed waste and water pollution.
7. The extruded feed can be sensed as attractant by means of fishes by using various its structure primarily based on fishes’ preference.
8. The younger fishes are free to digest and take in extruded feed pellets to get an brilliant growing.
9. To enhance fish feed quality, extrusion system can be used to improve greater feed materials, such as full-fat soybean powder, feather powder, blood powder, etc.
10. It is effortless to investigate and manage fish feeding circumstance to hold an most useful fish production.
11. There is low moisture content material in extruded fish feed pellet, which amenities long-term storage.
More at: www.fishfeedpelletizer.com |
