Keso2 Hifi obsluha
Založený: 08 október 2020 Príspevky: 7
Zaslal: Št október 08, 2020 20:21:37 Predmet: P: Stlpove reproduktory JBL LS80 - PREDANE |
Predám reproduktory JBL LS80, top end séria od JBL pre domáce použitie. EISA European Speaker of the Year 2008-2009. Ideálne v kombinácii so zosilňovačom Harman Kardon HK 990.
Pôvodné krabice, dôvod predaja pre prechod na vyššiu triedu. Bez poškodenia, s originál krabicami. Nové cca 2450EUR. Cena teraz 1900EUR
Špecifikácia.
3.5-Way, Dual 200mm Floorstanding Loudspeaker
Frequency Response (-10dB): 35Hz – 40kHz
Frequency Response (-3dB): 46Hz – 38kHz
Power Handling: 100W (continuous) / 200W (music) / 400W (peak)
Maximum Recommended Amplifier Power: 200W
Sensitivity (2.83V, 1m): 90dB
Crossover Frequencies: 400Hz, 6dB/octave; 2kHz; 8kHz; 24dB/octave
Nominal Impedance: 6 ohms
Low-Frequency Transducer: Dual 200mm with cast-aluminium frames
High-Frequency Transducer: 50mm pure-titanium compression driver; Bi-Radial® horn
Ultrahigh-Frequency Transducer: 19mm polyester-film ring-radiator; neodymium magnet; EOS waveguide
Dimensions (H x W x D): 1104mm x 259mm x 418mm
Weight: 35.6kg
68.2 KB |
81 Time(s) |
66.29 KB |
94 Time(s) |
