Vickyabc Ready2Die
Založený: 15 september 2021 Príspevky: 4
Zaslal: St september 15, 2021 10:19:43 Predmet: For your feet,Run an extra mile,Sprint all you can |
"Utilizing a simple theme, this nike air force 1 high zwart features a White, Team Red, and Green Abyss color combination. First, we have White tumbled leather across the uppers while the same shade hits the laces, midsole, and rubber outsole. Team Red appears on the ankle strap, Swoosh, and inside of the tongue. Following, Green Abyss lands on the strap buckle, tongue label, and heel overlay.
</br></br>
This nike air max 90 outlet comes dressed in a Summit White, Pomegranate, and Pink Glaze color combination. Constructed with recycled materials and fabrics, while Summit White takes over the base. Next, both Pomegranate and Pink detailing runs throughout while ’Terrascape’ branding lands on the tongue pull tabs and insoles. Lastly, we have a semi-translucent midsole and a Crater Foam outsole.
</br></br>
This air jordan 3 dames comes dressed in a Black, Pine Green, Cement Grey, and White color combination. Highlighted with Black nubuck on the upper instead of the traditional tumbled leather. Next, we have elephant print on the overlays around the toe and heel while Pine Green appears on the collar, eyelets, part of the midsole, and tongue branding. Finally, a White midsole and Grey rubber outsole finish the look.
</br></br>
Tapping into their brand color combination, Footpatrol has dialed the take a look with their signature white and grey hues. Metallic silver overlays run above the sneaker’s profile, while black and tan snakeskin runs across the Three Stripe branding. The sneaker is finished off with Footpatrol’s Gas Mask stamp of approval and an ankle strap." _________________ longlastingcomfort.com |
