seestyle Ready2Die
Založený: 01 august 2022 Príspevky: 84
Zaslal: Po august 01, 2022 11:14:20 Predmet: El Salvador vs. Canada time TV channel stream lineups bettin |
Even if Canada doesn't mathematically secure qualification on Wednesday evening which is a distant po sibility a win over El Salvador would just about put it on the precipice.
Les Rouges sit atop the , holding a four-point lead over the United States and Mexico, and they travel to San Salvador with the hope of going a perfect three-for-three international break.
If Canada secures victory, its second-ever World Cup appearance Colorado Rockies Jersey and first since 1986 would be surely on the horizon, with the final three matches a mere formality. An outside shot at mathematical qualification remains in this round, but all four results would have to align perfectly, a po sible but unlikely scenario.
MORE:
El Salvador, meanwhile, is hanging on by a thread. A win over basement-dwelling Honduras last time out was a lifeline, but the intercontinental playoff spot remains eight-points adrift, a nearly insurmountable distance.
How to watch El Salvador vs. CanadaDate:Wednesday, Feb. 2Time: 9 p.m. ETTV channel: UniversoStreaming:, Paramount+Wednesday's match between El Salvador and Canada from San Salvador will be broadcast on Universo. The match can beand new users can take advantage of.
MORE:
The match will also be carried by CBS streaming platform Paramount+ in the USA.
El Salvador vs. Canada projected lineupsEl Salvador's head coach Hugo Perez switched to a back-three in the last match, Sam Hilliard Jersey but it's hard to tell if the tactics had a tangibly positive effect on the squad or if Honduras was just too poor for it to matter. Look for Perez, who was happy with his side's performance against the United States despite the 1-0 lo s, to revert to a more traditional four-man backline setup.
A big mi s for El Salvador is midfielderBryan Landaverdewho is suspended for yellow card accumulation.Isaac PortilloorJairo Henriquez could be tabbed to fill in.
ExpectAlex Roldanto return to the lineup despite coming off the bench in the win over Honduras last time out, as he has proven a bright spot for El Salvador. GoalscorerDarwin Cerenalso may have earned a return to the starting XI. A decision at center back must be made betweenEriq Zavaleta,Eduardo Vigil, andRoberto Dominguez.
El Salvador projected starting lineup (4-3-3):Gonzalez (GK) Tamacas, Vigil, Zavaleta, Larin Ceren, Hernandez, Orellana Henriquez, Gil, Roldan.
Not only is Canada buzzing after the famous 2-0 win over the United States, but it also came out with a clean bill of health as well.
The only player unavailable for Canada heading into the El Salvador match isSteven Vitoriawho is suspended due to yellow card accumulation. Otherwise, only Alphonso Ryan McMahon Jersey Daviesremains out, having mi sed out on the international window altogether stemming from COVID-19.
MORE:
Doneil Henryis the likely candidate to replace Vitoria at center back. Otherwise, expect a similar or nearly unchanged starting lineup from the win over the United States.Alistair Johnstonwill look to reprise his Man of the Match performance at the back, with goalscorerSam Adekugbeon the other flank.
Up front,Jonathan DavidandCyle Larinhave proven they can not only coexist in the same lineup together, but thrive. In midfield,Atiba Hutchinsonreturns from suspension and will likely takeMark-Anthony Kaye's position in Blank Jersey midfield.Stephen Eustaquiohas reportedly shaken his COVID-19, but it's likely that Herdman will avoid making too many changes, and the Porto man could be used off the bench to ease his return.
Canada projectedstarting lineup (4-3-3):Borjan (GK) Miller, Henry, Johnston Adekugbe, Hutchinson, Osorio, Laryea David, Larin,Buchanan
El Salvador vs. Canada betting odds, pick& predictionOdds courtesy of DraftKings
Canada is flying of late, but it's hard to ignore just how competent and compact El Salvador has been this international window. La Selecta troubled the United States with its cohesive structure, just allowing the one goal.
It's entirely po sible that, with Canada traveling to the central American nation, still without its star Alphonso Davies, that this match could present some difficulty.
Historical pe simism hasn't bothered Canada in the slightest of late, as this is just a different Canada side than we've ever seen before. But of note, Les Rouges have won just two of their last five against El Salvador, and have not won on the road in San Salvador since 1996.
A low-scoring road draw here Kyle Freeland Jersey would be totally reasonable, and Canada would be more than happy with a point that still leaves it on the brink of World Cup qualification.
Pick:Draw & Under 2.5 goals (+255)
Prediction:El Salvador 1-1 Canada
Moneyline:El Salvador +340 / Draw +235 / Canada -120Spread: El Salvador +0.5 (-110) / Canada -0.5 (-125)O/U 2.5 total goals:Over +155 / Under -205Both teams to score: Yes +125 / No -165Canada can mathematically qualify for the World Cup if:Canada defeats El SalvadorHonduras defeats the United StatesMexico defeats PanamaJamaica defeats or draws with Costa RicaWith this exact combination of results, Canada would secure qualification to the 2022 FIFA World Cup.
Despite the fact that Panama and the United States would be theoretically within striking distance with three Chris Rusin Jersey matches to go (maximum nine available points), those two teams still have to face off one more time, meaning only one of the two not both could mathematically overtake Canada in the standings.
The most unlikely result is the United States falling to Honduras in Minnesota. While the USMNT has had its struggles this international window, it is still heavily favored against a Honduran side that has ma sively flopped throughout the Octagonal with just three points through 10 matches. _________________ John Short, Jr |
PierceWelsh Ready2Die
Založený: 09 august 2022 Príspevky: 45
Zaslal: Ut august 09, 2022 19:38:14 Predmet: |
| Very impressive, To start my feedback i would like to congratulate your team for giving us this source of knowledge and we are freely to connect with you too. Please have a sweet day by reading this, 바카라 수익내기 |
