Založený: 08 september 2010 Príspevky: 11531 Bydlisko: Praha
Zaslal: Št apríl 14, 2016 12:16:22 Predmet: Floyd Toole: clanky |
History of Multi-Sub & Sound Field Management (SFM) for Small Room Acoustics
citácia: | The problem with the small rooms we listen in is that they so often present us with offensive bass booms, and the bass is different at different seating locations. The traditional solutions for taming room resonances have relied on low-frequency absorption (a.k.a. bass traps), system layout, and manipulating room dimensions. In homes these may or may not be practical. So my team and I investigated alternative solutions, leading to multiple subwoofer strategies and a sophisticated DSP process called Sound Field Management (SFM). This article describes the evolution of these methods, that can replace or supplement bass traps in some situations. |
Viac: https://www.audioholics.com/room-acoustics/history-of-multi-sub-sfm
Clanok ma niekolko stran - na konci stranky je "Jump to".
Naposledy upravil miero dňa Ut august 20, 2019 08:41:51, celkom upravené 3 krát. |
Zaslal: Št apríl 14, 2016 12:17:23 Predmet: |
Room Reflections & Human Adaptation for Small Room Acoustics
citácia: | Dealing with acoustics in small rooms is no trivial matter. The quest for the “perfect” room all depends on your expectations, why you are listening (business or pleasure), what program you are listening to, and the condition of the ears you are listening through. This article focuses on the topic of early reflections in small room acoustics and how to deal with them based on listening preferences and the accuracy of your loudspeakers. The portions of side walls responsible for first lateral reflections are specified as “optional areas: absorb, diffuse, reflect.” It is a decision to be made by the customer and/or the installer. |
Viac: https://www.audioholics.com/room-acoustics/room-reflections-human-adaptation
Clanok ma niekolko stran - na konci stranky je "Jump to". |
Zaslal: Ut august 20, 2019 08:40:58 Predmet: |
The Measurement and Calibration of Sound Reproducing Systems
citácia: | The steady-state amplitude response measured at listening locations in a room is a widely accepted indicator of sound quality in sound reproduction systems. Room equalization schemes adjust the room curve to match a target believing that this ensures good and consistent sound.This paper examines both small and large venues, home theaters to cinemas, seeking a calibration methodology that could be applied throughout the audio industry. At present most of the industry follows a common philosophy but movie sound is a problematic exception. Some changes to current practice are indicated |
Viac: http://www.aes.org/e-lib/browse.cfm?elib=17839 (OpenAccess) |
