phocohanoi7 Ready2Die
Založený: 27 máj 2023 Príspevky: 4
Zaslal: St jún 07, 2023 03:19:52 Predmet: Prediction analysis Lahti vs HJK Helsinki 22:00 on June 7th. |
Prediction, analysis, Lahti vs HJK Helsinki, 22:00 on June 7th - Finnish Premier League. Predictions and odds analysis for the Asian handicap and over/under betting options for the match between Lahti and HJK Helsinki by top experts.
Want to get a head start on your soccer tips for tomorrow ? Check out our soccer tips for tomorrow, providing you with expert analysis and predictions to help you make informed decisions.
PREDICTION FOR LAHTI VS HJK HELSINKI
Lahti hasn't had a particularly good form since the start of this season (but not too bad either). They have only managed to win 1 match out of their first 8 matches in the Veikkausliga. Along with that, they have 4 draws and 3 losses.
Currently, Lahti is sitting in the 10th position out of 12 teams in the Finnish Premier League, but they have played fewer matches than the teams above and below them, ranging from 1 to 2 matches. If they can take advantage of this, they have a chance to escape relegation.
On the other hand, HJK Helsinki has played 11 matches, gaining 20 points, trailing the teams above them by 3 and 1 point respectively. However, HJK has played 2 more matches than the team directly above them (SJK Seinajoki).
HJK has also been dominant against Lahti, with 9 wins, 7 draws, and only 4 losses in their last 20 encounters. In their last 10 away matches against Lahti, they have won 5, drawn 3, and lost 2.
Download our betting tips app download to access daily recommendations and predictions from our team of experts, covering a range of markets including 1x2, over/under, and more
Curious about esports betting and wondering whether it's worth playing or not?
Analysis of the Asian handicap odds: Despite being the away team in this match, HJK Helsinki is still considered much stronger. With a handicap of -1, it is clear that the away team is highly reliable.
Pick: HJK Helsinki -1 for the whole match.
Analysis of the over/under odds: Out of the 11 matches HJK Helsinki has played so far this season, 7 of them have ended with no more than 2 goals scored. With an over/under line set at 2 1/2 for this match, the likelihood of a low-scoring game is quite high.
Pick: Under 2 1/2 for the whole match.
Score prediction: Lahti 0-2 HJK Helsinki
Asian handicap pick: HJK Helsinki
Over/under pick: Under.
Check out our guide on what is esports, types of esports bets, and whether to play esports https://wintips.com/what-is-esport-types-of-esport-bets-and-whether-to-play-esport-or-not/ |
