PRODAM VAN DEN HUL D 352 HYBRID repro kabely 2.5m 1500kc
dzyan
Založený: 05 marec 2008
PríspevokZaslal: Ut november 18, 2008 10:30:13    Predmet: PRODAM VAN DEN HUL D 352 HYBRID repro kabely 2.5m 1500kc Odpovedať s citátom
Prodam Van den Hul 2.5m.Cena velmi levne 1500kc
PCena za 1m 32 euro
The D - 352 HYBRID (Halogen Free)
http://imgupload.cz/s4/bZwbnNDmce.JPG
http://imgupload.cz/s4/lXirFPKej2.JPG
http://imgupload.cz/s4/NPclF6GkJr.JPG
http://www.vandenhul.com/UserFiles/Image/d-352-hS.jpg
Tel 724537600
This twin lead brown metallic coloured speaker cable is designed to provide a very high transfer quality at a moderate price.
Each lead is made of 296 x 0.15 mm. Matched Crystal (MC) high purity OFC strands with a dense and very pure silver coating.
Covering the two conductors an extra layer saturated with Linear Structured Carbon ® is applied to improve the sonic performance and to transform the radiated magnetic field into an audio signal again.
The cable jacket is made of our HULLIFLEX ® 3, a very flexible and mechanically superb insulation material.
The resistance per lead is: 0.34 Ohm/100 meter.
Total metal cross-section area for each conductor is 5.23 mm², equalling AWG 10. The capacitance between the 2 leads is: 32.5 pF/meter.
The plus and minus leads are different in jacket-shape with printing in the flat middle section. Both properties are easy polarity-finders.
Type printing at 25 cm. (10") distance makes cutting of specified lengths very easy.
Our 4.0 mm. Ø cable entrance diameter Bus type Universal Speaker Connectors and our DIY Screw-On Speaker Connectors are excellently suited for the D - 352 HYBRID.
Packing conditions: 50 meters per reel with a total shipping weight of 10.4 kg. incl. the packing box with external dimensions in mm.: 310 x 310 x 290.
Related Articles & Papers:
»Carbon_Links_-_Hi-fi_News_Jan_2000.pdf
Cable Type: Twin conductor
Conductor Material: HYBRID: High purity dense Silver coated high purity Matched Crystal OFC + Linear Structured Carbon ® saturated layer(s)
Design Purpose/
Application Area(s): Loudspeaker cable
Eff. Conductor Ø/Eq. AWG No./Strands: 2x(5.23 mm² / AWG 10 / 296)
External Diameter /
-Dimensions: 21.0 mm. wide; 6.5 mm. thick
Resistance 20 °C / 68 °F: 0.34 Ohm/100 m.
Capacitance: 32.5 pF/m.
Insulation / Dielectric Strength / Test Voltage: HULLIFLEX ® 3 / 300 Vrms min.
Connector Types Suitable: Our 4.0 mm. Ø cable entrance diameter Bus type Universal Speaker Connectors or our DIY Screw-On Speaker Connectors; Both
dzyan
PríspevokZaslal: Pi november 21, 2008 21:55:43    Predmet: Prodano Odpovedať s citátom
Tohle se mi jeste nestalo 3 kupci behem 15 minut.Prodano.
