alfaro Nádejný hifista
Založený: 31 december 2007 Príspevky: 86
Zaslal: So apríl 11, 2009 14:34:29 Predmet: DYNAUDIO CONTOUR 1.8MKII v Top stavu |
Prodám DYNAUDIO CONTOUR 1.8MKII v Top stavu
Prodám tyto legendární sloupové reprosoustavy špičkové měniče esotec,barva třešen,optický i technický stav perfektní.
Technical Specification I Contour 1.8 MK II
Sensitivity (2.83 V/1 m): 86 dB
Recommended Amp. Power: Small size rooms: >30 watts
Medium size rooms: >70 watts
Large size rooms: >130 watts
IEC Long Term Power Handling: 250 watts
Impedance, Nominal: 4 ohms
Impedance, (20 - 200 Hz): 3.8 - 9.4 ohms
Impedance, (200 - 20 kHz): 4.6 - 5.8 ohms
Impedance, Phase Shift (20 - 200 Hz): -22.2° - +28.8°
Impedance, Phase Shift (200 - 20 kHz): -0.6° - +9.3°
Impedance, HF (200 kHz): 7.6 ohms
Frequency Response (+/- 2 dB): 38 Hz - 20 kHz
Frequency Response (+/- 3.5 dB): 28 Hz - 30 kHz
Resonance Frequency: 27 Hz
Internal Cabinet Volume: 32.5 litres
Bass Principle: Bass reflex
Weight: 19 kg
Dimensions (W x H x L): 204 x 935 x 294 mm
Crossover: 2 way. The crossover is impedance corrected
Crossover Frequencies: 2600 Hz
Crossover Slope: Woofer: 6 dB/oct, Tweeter: 6 dB/oct
Connection: Dynaudio Terminal with WBT gold binding posts
Recommended Placing: Floor, free standing
Remarks: Tweeter: 28 mm soft dome.
Magnetic fluid.
Aluminium front.
Pure aluminium wire voice coil.
Rear chamber.
Double magnet system.
Woofer: 2 x 17 cm with 75 mm pure aluminium
wire voice coil.
Die cast basket.
Magnetically shielded.
High quality polypropylene capacitors
cena nových byla 90000kč,prodám za 35000kč,Dohoda MOŽNÁ
TEL:608707732,EMAIL:SPRINTKOLA@SEZNAM.CZ |
matus_pigy Hifista - pokročilec
Založený: 07 január 2009 Príspevky: 347 Bydlisko: Stupava
Zaslal: So apríl 11, 2009 16:16:27 Predmet: |
sakra keby som mal teraz peniaze... Toto je skvelá kúpa _________________ Hlavné stereo: (Auralic Aries mini + SP audio power supply -> SP audio D1 -> Ayre K5Xe -> Ayre V5Xe -> Dynaudio Contour 20i)+GIK Acoustics
Slúchadlá: Hifiman Ananda+Chord Mojo2 |
Zaslal: Ne apríl 12, 2009 07:26:14 Predmet: |
recenze v časopise audio kde zvítězily
Zaslal: Ne apríl 12, 2009 07:35:44 Predmet: |
Recenze s časopisu HIFI
Zaslal: Ut apríl 14, 2009 12:48:43 Predmet: |
| PRODÁNO |
