Richard_ke Hifista
Založený: 05 marec 2010 Príspevky: 100 Bydlisko: Kosice
Zaslal: Št marec 11, 2010 21:14:58 Predmet: Rproduktory Mission M32i |
Mission M32i pár reproduktorov, ako nové Anglickej značky Mission M32i
- reproduktory boli donesené na objednávku z U.K. pôvodná cena 200Libier, teraz 130Euro, možnosť osobného odberu v Košiciach
- farba Graphite /čierna, resp. antracitová/
- hrané menej ako 100hodín, zabalené v krabici komplet s papiermi
- Garantujem 100% Vašu spokojnosť produktu vrátením plnej sumy
- V prípade akýchkoľvek otázok ma kontaktujte na telefónnom čísle 0907 312 731
Details:
The Mission M32i is a stand-mount loudspeaker ideally suited to the Mission Stancette Stand. Similar to the M31i but with a larger 165mm DiaDrive bass unit, the Mission M32i provides deeper bass extension and impressive midrange performance. Mission's M32i speakers transmit power, excitement and emotion and excellence at an affordable price.
To match the outstanding performance of the new DiaDrive bass unit, a lightweight, Viotex fabric dome treble unit handles high frequencies up to an ultrasonic 28kHz. The true analysis of this extended bandwidth can be found in the sweetness, clarity and detail resolution that only comes from a drive unit that pushes distortion products beyond the limits of audibility.
The curved profile to the 30mm thick front baffle optimises dispersion and provides a rigid frame for the drive units in conjunction with the strongly braced 18mm MDF cabinet construction. The Mission M32i's crossover high uses high quality Audiophile grade capacitors to ensure high frequency clarity and also presents an easy amplifier load suits all types of amplification. The speakers are magnetically shielded suitable for close proximity to the television.
* Stand-mount loudspeaker ideally suited to the Mission Stancette Stand.
* DiaDrive Bass Unit Reveals the full energy of the music signal.
* High quality crossover bass components Laminated Silicon Iron coils reduce level dependant distortion.
* Anti-turbulence reflex port Low distortion bass extension.
* Available in Graphite black.
Specifications:
* Amplifier Power Range
25 to 100 watts
* Cross Over Frequency
2.8kHz
* Dimensions (HxWxD) in mm
320x200x325
* Effective Volume
12.4 litres
* Enclosure Type
2 way reflex loaded
* Finish
Graphite
* Frequency Response at 3dB
52Hz to 20kHz
* In room frequency bandwidth
-6dB at 58 to 28kHz
* Nominal impedance
8 ohm (min 40 ohms)
* Sensitivity SPL/m/2.83V
90dB
* Weight
14kgs
75.07 KB |
305 Time(s) |
78.6 KB |
296 Time(s) |
72.74 KB |
300 Time(s) |
milraz Hifista - zaslúžilec
Založený: 12 február 2008 Príspevky: 788 Bydlisko: bratislava
Zaslal: Pi marec 12, 2010 07:45:07 Predmet: |
| Nazdar mal by som zaujem o tie missiony no potreboval by som predat moje epos els3 hned ako sa mi to podari dam vediet,dnes sa veci tazko predavaju popripade ak by si mal zaujem o vymenu mam tu inzerat pozri epos els3 a stojany epos st35. 0908661576.
Richard_ke Hifista
Zaslal: Pi marec 12, 2010 08:57:54 Predmet: |
Ahoj. Dakujem za prejaveny zaujem, ak ich budem este mat, tak rad ti ich predam. Zial nemozem garantovat, ze ich budem mat Par ludi sa mi uz ozvalo a potrebujem nejaku hotovost, chcem totiz kupit Denon AVR 2808
Richard_ke Hifista
Zaslal: Ne marec 14, 2010 16:23:59 Predmet: |
| Stale aktualne.
Richard_ke Hifista
Zaslal: Po marec 15, 2010 16:17:01 Predmet: |
Richard_ke Hifista
Zaslal: St marec 17, 2010 19:45:24 Predmet: |
| Predane do BA, Dakujem vsetkym, co ma kontaktovali telefonicky alebo sukromnou spravou za prejaveny zaujem.
