hcrevize Hifi expert
furto Hifista - zaslúžilec
Založený: 26 január 2013 Príspevky: 691
Zaslal: Ne december 28, 2014 16:31:04 Predmet: |
Ano povodne bol na sekundari, tam to robilo vacsie problemy pri spustani.
Teraz ho mam na primari, chcel som to vyskusat aj na primari, istic padal menej casto. |
Zaslal: Ne december 28, 2014 17:36:58 Predmet: |
Symmetrical power idea has seductive appeal
120-volts between two 60-volt legs like 240-volts
between two 120-volt “phases” of utility power
In ideal world, it would completely cancel
leakage currents into safety ground system
Equal and opposite voltage swings across equal
capacitances would result in zero net current
In real equipment, capacitances from each leg to
chassis are very unequal, more often a 3:1 ratio
Actual noise reduction generally under 10 dB
and rarely exceeds 15 dB
May be cost-effective in certain video applications _________________ BW801, SPaudio P1, SPaudio A400, HTPC; SPaudio D1, LC1 repro kabel.
www.revize-hc.cz
www.customworks.cz
www.spaudio.cz |
Zaslal: Ne december 28, 2014 18:48:26 Predmet: |
40 uF je dosť veľa, stačí 10 uF. |
