patchkez Hifi obsluha
Založený: 22 november 2010 Príspevky: 9
Zaslal: Po november 29, 2010 09:29:06 Predmet: Lynx L22 - zvuková karta - PREDANÉ |
Predám zvukovú kartu Lynx L22 kupovanú v USA, originál balenie + komplet príslušenstvo.
200kHz sample rate / 100kHz analog bandwidth (Supported with all drivers)
Two 24-bit balanced analog inputs and outputs
+4dBu or -10dBV line levels selectable per channel pair
24-bit AES3 or S/PDIF I/O with full status and subcode support
Sample rate conversion on digital input
Non-audio digital I/O support for Dolby Digital® and HDCD
32-channel / 32-bit digital mixer with 16 sub outputs
Multiple dither algorithms per channel
Word, 256 Word, 13.5MHz or 27MHz clock sync
Extremely low-jitter tunable sample clock generator
Dedicated clock frequency diagnostic hardware
Multiple-board audio data routing and sync
Two LStream™ ports support 8 additional I/O channels each
Compatible with LStream modules for ADAT and AES/EBU standards
Zero-wait state, 16-channel, scatter-gather DMA engine
Windows 2000/XP/XPx64/Vista/Vistax64: MME, ASIO 2.0, WDM, DirectSound, Direct Kernel Streaming and GSIF
Macintosh OSX: CoreAudio (10.4)
Linux, FreeBSD: OSS
RoHS Compliant
Optional LStream Expansion Module LS-ADAT: provides sixteen-channel 24-bit ADAT optical I/O (Internal)
Optional LStream Expansion Module LS-AES: provides eight-channel 24-bit/96kHz AES/EBU or S/PDIF digital I/O (Internal)
Karta funguje aj pod OS Linux z OSS ovládačmi. Možnosť osobného predania v Brne. Predávam, pretože je nevyužitá.
Cena: 10 000,- CZK
Naposledy upravil patchkez dňa St október 10, 2012 10:29:50, celkom upravené 2 krát. |
Zaslal: Pi december 09, 2011 09:02:48 Predmet: Stále aktuálne |
Zaslal: St február 01, 2012 18:22:55 Predmet: |
| stále aktuálne... |
Zaslal: Po február 13, 2012 10:18:03 Predmet: |
Zaslal: Št február 23, 2012 09:47:03 Predmet: |
| - zlacnené na 9500 CZK |
Zaslal: Pi marec 16, 2012 15:10:31 Predmet: |
Zaslal: Št marec 22, 2012 10:46:57 Predmet: |
| stále aktuálne... |
Zaslal: Pi jún 29, 2012 11:14:52 Predmet: zlacnené |
| - zlacnené na 9000czk |
Zaslal: St október 10, 2012 10:29:17 Predmet: |
Predané |
