Soaron Hifi expert
Zaslal: Št december 21, 2017 20:15:27 Predmet: |
Škoda toho chýbajúceho DO u Pro verzie. Docela sa mi pozdáva aj dizajnom. A hlavne má to aj analógový vstup. _________________ PC - DIY silver USB - Denafrips Pontus II - DIY silver XLR - BVa PA300SSE - DIY silver XLR - BVa PRE 1 - Atohm Zef Max - STH12
Sony WH-1000XM4 |
Zaslal: St január 17, 2018 16:58:26 Predmet: |
Pouzivate DSP u toho DACu? Je to pouzitelne i pre room correction?
Z toho co som nasiel to na to moc nevyzera:
citácia: | However, when I wanted to use the EQ function for the correction of my monitor setup, I was very disappointed. Incomprehensibly, the frequency range of the individual EQ bands is limited which limits their meaningful use. Especially for the correction of room influences often more than two EQ `s, in the frequency range below 150 Hz, are necessary. This is not possible due to this nonsensical restriction. |
Zdroj: https://www.forum.rme-audio.de/viewtopic.php?id=24702
Nobv neskorsich verziach fw uz upravili DSP a umoznuju nastavit prve tri ekvalizery od 20Hz. |
TigiGold Hifista - pokročilec
Založený: 24 júl 2008 Príspevky: 429 Bydlisko: Praha
Zaslal: Pi január 26, 2018 11:34:13 Predmet: |
Na Thomannovi se objevila cena RME ADI-2 DAC, a to 990 EUR.
https://www.thomann.de/cz/rme_adi_2_dac.htm
Skladem ale bude až v polovině března. _________________ Audiolab 9000 CDT * RME ADI-2 DAC FS * Neumann KH310 * Sennheiser HD800 a HD650 * Beyerdynamic T1 * Avantone Planar * AKG K371 * Panasonic DMP-BDT380EG * Epson EH-TW5650 |
Hopp Hifista
Založený: 18 december 2007 Príspevky: 201 Bydlisko: BA
Zaslal: Pi január 26, 2018 13:08:01 Predmet: |
miero napísal: | Pozeram do materialov, ale neviem tam najst ci to ma galvanicky oddeleny USB vstup od audio casti. Je mozne, ze ho nema izolovany?
Inak vyzera to by pekny pristroj. Ale tej prace to vsetko vyrobit a naprogramovat, nedivim sa tej cene. A to je zrejme seriovy vyrobok... |
Galvanicky oddeleny USB vstup to nema, ale co si o tom mysli sef RME uviedol v jednom vlakne na fore tohto produktu, kde v tomto poste vyjadrujucom sa aj k jitter "cisticom" napisal nasledovne:
Sowohl unsere USB Hardware als auch die Treiber sind komplette Eigenentwicklungen, während die große Masse der DACs Drittfirmen-Lösungen wie XMOS nutzt, und dazu wieder andere Treiberlieferanten. Da die USB Ports von Pro und DAC keine Buspower nutzen sind typische USB-Cleaner und Jitterentferner komplett nutzlos. Das einzige nachrüstbare Merkmal, welches unter Umständen Sinn macht, ist galvanische Trennung des USB à la Intona. Das merken Sie dann aber nicht in feinen Details und Tiefe der Bühne, sondern ganz profan in Störgeräuschen. Keine solchen - keine galvanische Trennung notwendig. Und das ist der Normalfall. |
BlackBerry Hifi inventar
Zaslal: Po február 12, 2018 11:29:13 Predmet: |
BlackBerry, ma vobec poistku, ktora by sla vymenit? |
Zaslal: Po február 12, 2018 11:49:52 Predmet: |
Možno. A ak nemá dá sa tam dorobiť klasické poistkové puzdro.
Tak určite.
A píš ku otázke ako som sa pýtal a nie provokačne.Ak máš reálnu posluchovu skusenosť. Dakujem. |
moses Hifi expert
Zaslal: Po február 12, 2018 12:03:08 Predmet: |
miero napísal: | BlackBerry, ma vobec poistku, ktora by sla vymenit? |
Ak ano, tak v jedine adapteri a ten sa bude sakra zle rozoberat _________________ SET01: PC + CA DacMagic Plus + KRK Rokit 4 G3 SET02: NTB + Echo Indigo IOx + Beyerdynamic DT 831 SET03: HTPC + ASUS Xonar STX + Bryston BP4 + Behringer TRUTH B3030A SET04: MP + AudioQuest Dragonfly Black + Sennheiser HD 25-C II |
Zaslal: Po február 12, 2018 12:04:58 Predmet: |
ziadnu. ale je skoro az zabavne ake masove nakupy tohoto i starsieho pro prevodniku sa tu deju. kto ma este len ca dac magic, ten uz nie je cool. teraz leti RME! :)) |
Zaslal: Po február 12, 2018 12:09:18 Predmet: |
Každý rok možno bude lepší a kvalitnejší vyrobok.
Ano RME teraz letí lebo tá firma je už dlhšie aj v profi známa a vyrába a ponuka slušné veci.
V cene 1000€ tažko niekdo ponukne aj Ekvalizer v DAC ,vyladené ovladáče a ostatné veci okolo.
Klasika ....
Zase si ho asi nepočul a neporovnával z iným a len tu šaškuješ.
Ty nemáš žiadny svoj názor len zosmiešniť všetko ostatné čo nemáš alebo nemaju Tvoji kamarádi. |
Zaslal: Po február 12, 2018 12:27:57 Predmet: |
Nepride ti vtipne, ze hifisti chcu zrazu pouzivat ekvalizer? :-)
Ten ekvalizer v RME zrejme nebude stacit pre korekcie miestnosti, takze ti co pouzivaju SW DRC, budu to SW DRC pouzivat nadalej. Ale na jemne ubranie vysok ci basov pre lepsi pocit asi stacit bude.
Inak moja vyhrada k tomuto je uz zial klasicka, a to ze to nema galvanicku izolaciu USB vstupu. Co asi vadi menej ak sa pouziju XLR vystupy (pripadne sluchadla), ale vadit to bude viac pri pouziti RCA.
Navyse DAC pre hifistov ma podla vsetkeho XLR vystupu trochu "ofejkovane", kedze nejdu pouzit na symetricky zapojene sluchdla.
Co samozrejme neznamena, ze to nie je dobry DAC. No uprimne, nejak z dialky nevidim dovod pripadneho zvukoveho prinosu, napr. oproti takemu CA DacMagicu Plus. |
Zaslal: Po február 12, 2018 12:29:56 Predmet: |
Presne teoretická rovina bez posluchu.
Napíš RME ako to maju robiť.
Vševedko. |
bvgsxduij112 Ready2Die
