Troton Site Admin
Zaslal: St jún 20, 2007 11:28:51 Predmet: NAD Powerdrive-S |
Ide o technologiu pouzitu pri najlacnejsom NAD C315BEE.
Je mi jasne o co im ide, ale sposob, akym to dosiahli veru uplne nie :
http://nadelectronics.com/powerdrive-s
This design delivered extraordinary reserves of tone-burst power for music from an output stage delivering dual voltages roughly in the proportion 1.4:1. In the case of the C315BEE both supplies are fed from a low resistance 150VA toroidal transformer but the higher voltage winding has PTC (Positive Temperature Coefficient) resistances in series.
Fast-Forward to Today A Light Switched On, Actually Two
Amazingly, two modern long life quartz halogen light bulbs meet our needs more ideally than these thermistors providing cost effective, dynamic power (10- 100msec bursts) to a typical music envelope for a given maximum output stage dissipation. The light bulbs have very low resistance (<1 Ohm) when cold so drop very little voltage on short peaks. At 7 V, after a few hundred milliseconds, the resistance rises to an ideal 4 Ohms.
Pomocou seriovo zapojenych ziaroviek (mini) halogenovych ziaroviek a ich tepelnej charakteristiky (PTC) upravuju rezistenciu druheho sekundarneho vinutia s vyssim napatim na trafe a tym umoznuju odobrat kratkodobo z trafa celkovo vacsi vykon ? Nejako mi to nejde do hlavy.
Zaujimave je aj, ze pri predch.modeli (non budget) to iste vraj riesili pomocou:
OPAmps x 2
Thyristors x 4
Transistors x 10
Resistors x 20
Capacitors x 6
Aky mate na to technicky nazor ? |
coffee Hifi expert
Zaslal: St jún 20, 2007 15:29:23 Predmet: |
Naposledy upravil coffee dňa Št jún 03, 2010 21:03:18, celkom upravené 1 krát. |
Zaslal: St jún 20, 2007 15:57:33 Predmet: |
Možné riešeniezdroja je na obrázku, je to stará finta...Odpory predstavujú žiarovky.Pri vyššej záťaži klesne napätie za žiarovkami tak, že sa otvoria diódya ide to z nižšieho napájania(sinusový výkon)..
Každé trafo znesie krátkodobé preťaženie, obmedzenie je teplotou, pre hudbu to nie je kritické. Konce (SOAR) ale musia byť dimenzované na plné napájacie napätie.
Nevýhoda je vyššia strata na koncoch pri malých výkonoch ,idú z vyššieho napatia, a hlavne kolísanie napájania (PSRR konca, prieniky z napájania-vyššia impedancia zdroja) a rozptylové pole preťaženého trafa.
Je to snaha z lacnejšieho trafa dostať vyšší "dynamický" výkon. |
Troton Site Admin
Zaslal: St jún 20, 2007 18:22:01 Predmet: |
| BV napísal: | Možné riešeniezdroja je na obrázku, je to stará finta...Odpory predstavujú žiarovky.Pri vyššej záťaži klesne napätie za žiarovkami tak, že sa otvoria diódya ide to z nižšieho napájania(sinusový výkon)..
Vdaka za nazorne vysvetlenie.
Priblizne tak som si to nejako predstavoval, len mi neslo do hlavy, ze tolko spekuluju tam, kde sa to da vyriesit len o malo vacsim trafom bez uprav.
Nuz, je to entry model za cca 10K penazi, naklady su naklady = kapitalizmus a marketing nepusti.
Treba si asi zvyknut, ze sa tam pozera na par 100 korun aj pri takychto zasadnych veciach
Bohvie, ako sa to sprava v tych spickach,co tam zase pribudne vdaka zmene napajania, ked menia diody svoj stav.
Ale to nie je nasa starost  |
coffee Hifi expert
Zaslal: St jún 20, 2007 18:28:55 Predmet: |
Naposledy upravil coffee dňa Št jún 03, 2010 21:03:29, celkom upravené 1 krát. |
Zaslal: St jún 20, 2007 18:58:16 Predmet: |
Možná jsou to hausnumera, ale:
* 10k - 19% DPH zbývá 8.400
* obchodník marže 30% zbývá 6400
* dovozce/velkoobchod marže 30% zbývá 4900
* západní majitel značky/marketér marže 70% zbývá 2800
* čínský výrobce/vývojář zisk 20% zbývá na materiál/výrobu/vývoj 2300
Zisk primárního výrobce 500 Kč, bude-li materiál o 160Kč dražší, klesá zisk o 30% a to je sakra rozdíl. |
Troton Site Admin
Zaslal: St jún 20, 2007 18:58:28 Predmet: |
| coffee napísal: | 100 korun ??????!!!!!! to už je IMHO u takovýho stroje strašně moc, ono ten seznam součástek hovoří sám za sebe, tam je krásně vidět jak se šetří na každým odporu. Bohužel to je stejně jen pár lidí co si potřebujou vydělat nic víc nic míň, pokud ten produkt lidi přijmou tak je jim jedno co je uvnitř krabičky  |
Viem, co chces povedat, ale hifi znacka NAD kludne ten model mohla podla mna predavat o 400Sk drahsie, a bol by podla mna predajny rovnako, ludia by ho kvoli znacke kupili. Ale tam je cenovo prilis blizko o stupienok lepsi model, takze asi preto. kazdopadne v tejto kategorri take riesenie postacuje, takze su vsetci spokojni.
Inak tuto technologiu maju vsetky ich zosilovace, vratane Master serie.
K tomu zoznamu suciastok: ak myslis ten v mojom poste, to je zoznam suciastok v obvode Powerdrive pri vyssom modeli  |
coffee Hifi expert
Zaslal: St jún 20, 2007 19:05:42 Predmet: |
Naposledy upravil coffee dňa Št jún 03, 2010 21:03:43, celkom upravené 1 krát. |
platonik Hifi obsluha
Založený: 24 máj 2007 Príspevky: 46 Bydlisko: Bratislava
Zaslal: St jún 20, 2007 21:39:28 Predmet: NAD powerdrive |
Powerdrive mali aj staršie modely napr. C320, C350, C352 ... Pre bádateľov je možné stiahnuť pomerne ľahko schémy tu:
http://zeuslab.narod.ru/Schemes.htm |
ferenc Hifi expert
Zaslal: Št jún 21, 2007 07:56:23 Predmet: |
coffee (resp. aj ini), mozes sa mrknut do schemy a povedat ako sa bude pacit tomuto stroju ked mu vyskratujem reprosvorky ???
http://zeuslab.narod.ru/schemes/C320BEE.pdf
dikes
aj za schemy .. |
coffee Hifi expert
Zaslal: Št jún 21, 2007 08:28:03 Predmet: |
Naposledy upravil coffee dňa Št jún 03, 2010 21:03:56, celkom upravené 1 krát. |
Troton Site Admin
Zaslal: Št jún 21, 2007 11:25:37 Predmet: Re: NAD powerdrive |
Vdaka za naucnu stranku  |
