Hyri Hifi obsluha
Založený: 21 február 2014 Príspevky: 39
Zaslal: Po apríl 21, 2014 14:41:47 Predmet: ROTEL RSX 1057 |
Predam ROTEL RSX 1057.
http://elektro.bazos.sk/inzerat/36375646/Rotel-RSX-1057-Surround-Sound-Receiver.php
Cena: 449E
popis :
Model RSX-1057
AUDIO -
Continuous Amplifier Power
(Five channels driven) 75 watts/ch (20-20k Hz, <0.05% THD, 8 ohms)
(two channels driven) 100 watts/ch (1kHz, <1.0% THD, 8 ohms, DIN)
Total Harmonic Distortion <0.09 %
Intermodulation Distortion (60 Hz:7 kHz) <0.05 %
Frequency Response -
Analog Bypass 10 Hz - 120 KHz, ± 3 dB
Digital Input 10 Hz - 95 KHz, ± 3 dB
Signal to Noise Ratio (IHF A-weighted) -
Analog Bypass 95 dB
Digital Input 0 dBFs (Dolby Digital, dts) 92 dB
Input Sensitivity/Impedance Line Level: 200 mV/100K ohms
Contour (LF / HF) ± 6 dB at 50 Hz / 15 KHz
Preamp Output Level/Impedance 1.0 V / 1K ohm
Decodable Input Signal Dolby Digital, Dolby Digital EX, Dolby Prologic IIx, DTS, DTS_ES, DTS96/24, LPCM (up to 192K), HDCD, MP3, MPEGMultichannel
Video -
Frequency Response 3 Hz - 10 MHz, ± 3 dB (Composite, S-Video)
3 Hz - 100 MHz, ± 3 dB (Component Video)
Signal to Noise Ratio 45 dB
Input Impedance 75 ohms
Output Impedance 75 ohms
Output Level 1.0 Volt
FM Tuner -
Usable Sensitivity 14.2 dBf
Signal to Noise Ratio (at 65 dBf) 70 dBf
Harmonic Distortion (at 65 dBf) 0.03%
Stereo Separation (1 kHz) 45 dB
Output level 1 V
Antenna Input 75 ohms unbalanced
AM Tuner -
Sensitivity 500 uV/m
Signal to Noise Ratio 40 dB
Output level 500 mV
Antenna Input Loop Antenna
General -
Power Consumption: 450 watts, Standby
6 watts
Power Requirements
(AC) 115 volts, 60 Hz (USA version)
230 volts, 50 Hz (CE version)
Dimensions (W x H x D): 432 x 162 x 442 mm
17 1/8 x 6 1/2 x 16 5/8"
Front Panel Height 150 mm, 5.9"
Weight (net): 17 Kg, 38 lbs. _________________ B&W 604 S3 , Onkyo TX SR 600E |
