Kenwood KRF-V5100D
Peter2
Založený: 13 október 2013
PríspevokZaslal: Po apríl 25, 2016 18:26:59    Predmet: Kenwood KRF-V5100D Odpovedať s citátom
Predam AV 5.1 zosilovac Kenwood KRF-V5100D, dialkove, malo pouzivany, zachovaly, po prvom majitelovy. Cena 90e
Key Features
5-Channel Amplifier
Easy Setup Function
Dolby Digital EX, DTS-ES Ready
Full Automatic Digital Analogue Source Selector
Amplifier Features
Maximum Surround Output Power 5 x 120 Watt
Maximum Stereo Output Power 2 x 120 Watt
Tuner Features
Tuner (AM/FM) Yes
Radio Data System Yes
Enhanced Other Network (EON) Yes
Radio Text Yes
Program Type (PTY) Yes
Number of Presets 40
Timer No
Surround Formats
DTS-ES (Discrete 6.1) Yes
DTS-ES (Matrix 6.1) Yes
DTS Neo: 6 (Cinema/Music) Yes
Dolby Digital EX Yes
Dolby Digital Yes
Dolby Pro Logic IIx Yes
Dolby Pro Logic II Yes
Dolby Pro Logic Yes
DSP 5 Modes
DSP Modes Arena/Jazz Club/Theater/Stadium/Disco
Audio Features
D/A Converter 24-Bit/96kHz
Midnight Mode for Dolby Digital/DTS Yes
Active EQ Yes
Tone Control Bass/Treble
Loudness Yes
General Features
Easy Setup Function Yes
Variable Input Sensitivity 3 steps
Digital Recording Mode (Auto/Manual) Yes
Remote Control System Remote with Kenwood DVD Control
Digital Inputs/Outputs
Optical Audio Input/Output 1 / -
Coaxial Audio Input/Output 2 / -
Digital Input for 24-Bit/96kHz Yes
Analogue Inputs/Outputs
RCA Audio/Video Inputs 2 A / 3 AV
RCA Audio/Video Outputs 1 A / 1 AV / 1V
Composite Video Inputs/Outputs 3 / 2
6-Channel Input for DVD-Audio/SACD Yes
Pre-outputs SW/SBL/SBR
Switched AC Accessory Outlets Yes
Screw-type Speaker Terminals No
Push-type Speaker Terminals All
Headphone Jack (6.3 mm) Yes
75 Ohm FM Antenna Connector Yes
AM Antenna Connector Yes
Audio Specifications
Rated Stereo Output Power (FTC) 2 x 100 Watt (63Hz ~ 12.5kHz, THD 0.7%, 6Ω)
Effective Stereo Output Power 2 x 120 Watt (1kHz, THD 10%, 6Ω)
Effective Surround Output Power (THD 0.7%) 5 x 100 Watt (1-ch driven, (1kHz, THD 0.7%, 6Ω)
Effective Surround Output Power (THD 10%) 5 x 120 Watt (1-ch driven, (1kHz, THD 10%, 6Ω)
Total Harmonic Distortion 0.05% (1kHz, 50W, 6Ω)
Frequency Response Analogue Line Input 20Hz ~ 70kHz, 0dB ~ -3dB
Signal/Noise ratio (IHF\'66): Line input 95dB
Input Sensitivity/Impedance: Line Input 550mV (47kΩ)
Input Sensitivity/Impedance: 6-channel I
 Filesize:  175.95 KB
 Viewed:  107 Time(s)
 Filesize:  214.14 KB
 Viewed:  119 Time(s)
NAD M3, CA Magic Stream 6, Synology DS416play, Chord Carnival SilverScreen, Chord Chameleon VEE 3 stereo RCA interconnect, Velodyne SPL-1200R, Focal chord 826W
Peter2
PríspevokZaslal: St máj 04, 2016 10:00:56    Predmet: Odpovedať s citátom
nova cena 80e
