Bartoli Hifi inventar
Zaslal: Ut september 13, 2016 13:40:25 Predmet: |
Tak Mirku a jak to srovnani flaskovyho vysokozkreslujiciho VTL s tranzistorakem adcom GFA-555 dopadlo? |
Zaslal: Ut september 13, 2016 15:16:26 Predmet: |
| citácia: | | When considered overall, the results indicate to a high degree of confidence that a small but real audible difference exists between the Adcom GFA-555 and VTL 300W monoblocks when used to drive B&W 801 loudspeakers. |
Zdroj: http://www.stereophile.com/content/blind-listening-page-6 |
Zaslal: Ut september 13, 2016 16:49:44 Predmet: |
| miero napísal: | | citácia: | | When considered overall, the results indicate to a high degree of confidence that a small but real audible difference exists between the Adcom GFA-555 and VTL 300W monoblocks when used to drive B&W 801 loudspeakers. |
Uznavam ze je to zatizene balastem a hifikydanim omacky - jak jsme na to uz bohuzel zvykli ze Stereophile i u JA, takze clovek musi i trochu cist mezi radky....imho se Mirku nehrnes do toho "to" napsat narovinu a nechces celit mistnim hifistum?
Nicmene to napisu za tebe - srovnaval se ultra blby lampac s velmi vysokym zkreslenim jako prase s obycejnym nizkozkreslujicim zesem, oba zesy s velkym vykonem 300W a 200W/8.
Vysledky jsou:
vetsina lidi neslysela jako rozdil vubec nic, zejmena na zanrech popina-pipina. Trochu rozdily nekteri, ale opravdu malo slyseli u Fureho - vazna hudba.
Cely je to echt trapny protoze jak se zda ani opravdu silne zkreslujici lampy nejsou rozeznatelny od obycejnyho nizkozkresuliciho zesilovace.
Abych parafrazoval mistra: hifisti a jejich hmyzi sukani na zesilovaci  |
WaVe_99 Hifista - zaslúžilec
Založený: 12 december 2006 Príspevky: 689
Zaslal: St september 14, 2016 00:40:50 Predmet: |
| Bartoli napísal: | | miero napísal: | | citácia: | | When considered overall, the results indicate to a high degree of confidence that a small but real audible difference exists between the Adcom GFA-555 and VTL 300W monoblocks when used to drive B&W 801 loudspeakers. |
Vysledky jsou:
Mas pravdu, nekteri jsou i tak dementni, ze kolikrat vystridaji flasky za rovnej trandak a u obojiho si chrochtaji a to i na klasice. Hifisti, jak rikas. _________________ Omlouvám se, jsem hifitele
Když se na světe objeví opravdový génius, pozná se podle toho znamení,že se všichni hlupci proti němu spolčí. JONATHAN SWIFT |
Zaslal: St september 14, 2016 06:48:46 Predmet: |
Bartoli, este k tomu testu:
- rozdiel vo zvuku medzi zosilnovacmi bol preukazany
- identifikovat prave hrajuci zosilnovac sa moc nedarilo
- porovnanie bolo tazsie nez tvorcovia ocakavali, pretoze pred testom bol rozdiel "priepastny"
- ciastocny dosledok je, ze asi nema zmysel robit podobne slepe testy v malom, ale je treba velkeho poctu ucastnikov, aby sa vobec nieco ukazalo
- iny mozny sposob ako porovnavat zvuk tu demonstroval PMA - nahravky zvuku od repro, a potom kriticky posluch na sluchadlach
A ak mozes, skus obmedzit urazanie ludi ktorych si nevazis.... |
cough Hifi obsluha
Zaslal: St september 14, 2016 07:07:03 Predmet: u.i. V. |
A čo sa vám na tom terazky nepáči, Jasánek? Veď predsa pekne konštantne smeruje. Však keď tuná aj iní konštantne smerovali, tak ste povedali, že je to prínos pre túto komunitu, však Jasánek? _________________ No matter what measurements tell us, a loudspeaker isn't good until it sounds good. Dr. Floyd Toole |
Zaslal: St september 14, 2016 07:08:20 Predmet: |
| Dalsi posluchac vaznej hudby z vyhranenym nazorom... ste si dost podobni. |
cough Hifi obsluha
Zaslal: St september 14, 2016 07:17:15 Predmet: u.i. VI |
Prínos, Jasánek, prínos!!! _________________ No matter what measurements tell us, a loudspeaker isn't good until it sounds good. Dr. Floyd Toole |
Zaslal: St september 14, 2016 07:17:59 Predmet: |
| Chápu, když z tebe kape malost kudy chodíš, nemá smysl to už ani vytírat. |
Zaslal: St september 14, 2016 07:23:51 Predmet: |
Uznavam ze je to zatizene balastem a hifikydanim omacky - jak jsme na to uz bohuzel zvykli ze Stereophile i u JA, takze clovek musi i trochu cist mezi radky....imho se Mirku nehrnes do toho "to" napsat narovinu a nechces celit mistnim hifistum? |
Nabízím ještě jiné shrnutí:
"When they learned the price differential between two power amps that they themselves couldn't really tell apart, a large number of the listeners indicated that the extra bucks wouldn't be worthwhile to them personally. Often this comment took the form of "I'd buy the cheaper one and a new car."
Pokračuje to ovšem legračně:
"In turn, this train of thought leads on into concern about the cost/sonic-quality relationships of audio components, and thence into how that impacts on enjoyment of music reproduction in the home. Perhaps there will eventuate thoughtful explorations of these matters, either in the pages of Stereophile, or elsewhere, or both."
http://www.stereophile.com/content/blind-listening-page-5#llPe3bAlShOZs8f4.99 |
Zaslal: St september 14, 2016 07:24:31 Predmet: |
| cough: skus prehodnotit toho Gardinera v avatari, nehodi sa uz k tebe |
Zaslal: St september 14, 2016 08:35:03 Predmet: |
To nelze doporučit. Zkusil jsem první tři odstavce, zní to jako Harun Yahya nebo MaK  |
Zaslal: St september 14, 2016 08:43:47 Predmet: |
ok, inak nasiel som to, ze sa to neskor odkazuje na ten test:
| citácia: | ... In addition, Stereophile's blind amplifier tests conducted during the Stereophile Bay Area Hi-Fi Show in 1989 revealed sonic differences between an Adcom GFA-555 and VTL 300W Deluxe monoblocks. However, the results were incorrectly reported—in a paper given at the AES conference attacking the audiophile position—to be of no statistical significance. I refer the reader to the letter in Vol.12 No.10 from Professor Herman Burstein, one of the country's foremost statisticians, who did find a degree of statistical significance in the test results. When JA informed Tom Nousaine, author of the paper that incorrectly ascribed no significance to our results, that Professor Burstein had indeed found a small but nevertheless statistically acceptable evidence of differences between amplifiers, Mr. Nousaine responded that the established acceptance criterion for recognizing a difference was therefore too low. Furthermore, he attempts to discredit even statistically significant evidence of differences in this quote from his paper: "It is wise to be suspicious of results which are barely significant in any endeavor."
If differences do exist between components, why don't blind tests conclusively establish the audibility of these differences? I believe that blind listening tests, rather than moving us toward the truth, actually lead us away from reality. ... |
Zdroj: http://www.stereophile.com/content/deeper-meanings-page-3 |
Zaslal: St september 14, 2016 09:01:23 Predmet: |
| citácia: | | If differences do exist between components, why don't blind tests conclusively establish the audibility of these differences? I believe that blind listening tests, rather than moving us toward the truth, actually lead us away from reality. ... |
To je nádherná ukázka. Začíná se předpokladem, o kterém se nic neví, následuje proto zcela neopodstatněné, ale o to sugestivnější zpochybnění, a v druhé větě už je předpoklad mlčky považován za splněný, na základě čehož se vyslovuje další takový. V podstatě jsou to věty bez obsahu, úplně o ničem a k ničemu, přesto má pisatel zjevně dojem, že tím vyjádřil nějakou relevantní myšlenku. Přesný opak je přitom pravdou. Říká se tomu leap of faith. Už schází jen to, aby tomu dal někdo palec nahoru. A potom další, a další. A tak furt dokola. |
Zaslal: St september 14, 2016 09:40:04 Predmet: |
| Podobne uvazuje mozno i 99% ludi... je to pisane pre nich, a ani autor zda sa, ze nie je vedec. |
Zaslal: St september 14, 2016 09:45:59 Predmet: |
| Ještě si to může dát někdo do podpisu. A jsem zvědavý, kolik lidí to teď na just udělá, jen proto, že jsem to napsal. Tak potom poznáš už úplnýho blba. |
Zaslal: St september 14, 2016 09:59:22 Predmet: |
| MaBat napísal: | | citácia: | | If differences do exist between components, why don't blind tests conclusively establish the audibility of these differences? I believe that blind listening tests, rather than moving us toward the truth, actually lead us away from reality. ... |
Přesně tak. |
Zaslal: St september 14, 2016 12:00:33 Predmet: |
| miero napísal: | | cough: skus prehodnotit toho Gardinera v avatari, nehodi sa uz k tebe |
No jo dela Gardinerovi ostudu
Miro ale stejne jsi pripad, umne balancujes na hrane a nezavidim ti to  |
sekal Hifi expert
Založený: 26 január 2007 Príspevky: 1413
Zaslal: St september 14, 2016 12:49:48 Predmet: |
| Bartoli napísal: | | No jo dela Gardinerovi ostudu | Ne, nedělá. Zato ty CB ano, a velkou. A nejen jí, ale celému lidskému pokolení.. |
Zaslal: St september 14, 2016 12:51:38 Predmet: |
| sekal napísal: | | Bartoli napísal: | | No jo dela Gardinerovi ostudu | Ne, nedělá. Zato ty CB ano, a velkou. A nejen jí, ale celému lidskému pokolení.. |
Zmen si ten podpis, znevazujes praci F. Tooleho. |
Zaslal: St september 14, 2016 13:03:42 Predmet: |
| sekal: Bartoli ma tam zda sa Renee Fleming, ale tu nejde na rozdiel od Gardinera dobre poznat. Ale tiez jej robi hanbu. |
sekal Hifi expert
Zaslal: St september 14, 2016 13:10:38 Predmet: |
| Bartoli napísal: | | Zmen si ten podpis, znevazujes praci F. Tooleho. | Ne, nezměním. Ten (autentický) výrok je tam speciálně kvůli tobě a MaBatovi. Jde o novou, podprahovou metodu léčby v indikaci F60.2. A funguje dokonale, jak vidím. Já jsem spokojen..
Miero : Drobná nepřesnost. Za CB si tedy dosaď RF. (I když to lze vlastně nechat tak, resp. pouze rozšířit, poněvadž PF dělá ostudu jak svému avataru, tak nicku).. |
Zaslal: St september 14, 2016 13:12:49 Predmet: |
| sekal napísal: | | Bartoli napísal: | | Zmen si ten podpis, znevazujes praci F. Tooleho. | Ne, nezměním. Ten (autentický) výrok je tam speciálně kvůli tobě a MaBatovi. Jde o novou, podprahovou metodu léčby v indikaci F60.2. A funguje dokonale, jak vidím. Já jsem spokojen.. |
Ten výrok, který není ani trochu autentický, je tam speciálně proto, protože jsi debil. |
sekal Hifi expert
Zaslal: St september 14, 2016 13:18:57 Predmet: |
Vidíte to ? Účinnost je skutečně nevídaná. Něco jako mucholapka na deprivanty.. |
Zaslal: St september 14, 2016 13:22:52 Predmet: |
A můžeš mi vysvětlit, v čem má spočívat ta léčba? Nějak tomu nerozumím. Možná ani nemám.
Naposledy upravil MaBat dňa St september 14, 2016 13:23:22, celkom upravené 1 krát. |
Zaslal: St september 14, 2016 13:23:20 Predmet: |
| WaVe_99 napísal: | | Bartoli napísal: | | miero napísal: | | citácia: | | When considered overall, the results indicate to a high degree of confidence that a small but real audible difference exists between the Adcom GFA-555 and VTL 300W monoblocks when used to drive B&W 801 loudspeakers. |
Vysledky jsou:
Mas pravdu, nekteri jsou i tak dementni, ze kolikrat vystridaji flasky za rovnej trandak a u obojiho si chrochtaji a to i na klasice. Hifisti, jak rikas. |
Ty jsi to Vlnko nepochopil, ten clanek vyzniva naopak tak ze slyset vliv zesilovace na zvuku pres repro BWM801 nejde a to i v extremne vyhrocenem srovnani ultranahovno flasky vs malozkreslujici tranzistory
Z toho clanku mimo jine logicky plyne ze slyset rozdily mezi ultranizko zkreslujicimi zesy uz tuplem neni mozne.
Je to zde nepopularni psat a treba Mirek zbabele nenapise nic aby si to nerozhazel s mistnimi hifisty
A logikaclanku je neuprosna: kdyz ani ty VTL flasky nahovno zkreslujici jako prase nevadi tak teda i nahovnozkreslujici flasky jsou furt lepsi nez jakykoliv reprosoustavy.
Naposledy upravil Bartoli dňa St september 14, 2016 13:34:22, celkom upravené 1 krát. |
Zaslal: St september 14, 2016 13:32:21 Predmet: |
| Bartoli napísal: | | Z toho clanku mimo jine logicky plyne ze slyset rozdily mezi ultranizko zkreslujicimi zesy uz tuplem neni mozne. |
To rozhodne neplynie. Ak uz to chces tvrdit, tak napis napr., ze to z toho ide extrapolovat. |
Zaslal: St september 14, 2016 13:44:56 Predmet: |
| miero napísal: | | Bartoli napísal: | | Z toho clanku mimo jine logicky plyne ze slyset rozdily mezi ultranizko zkreslujicimi zesy uz tuplem neni mozne. |
Nemel jsi sem ten odkaz davat, jak se rika nasral jsi si do vlastniho hnizda  |
Zaslal: St september 14, 2016 13:47:22 Predmet: |
| Odkaz s tym nesuvisi. Ten zaver si si vymyslel sam, a tvrdis ze to plynie z toho clanku co som sem dal :D |
