BlackBerry Hifi inventar
Zaslal: Št november 17, 2016 10:36:23 Predmet: |
Sound localization
Sound localization refers to a listener’s ability to identify the location or origin of a detected sound in direction and distance. It may also refer to the methods in acoustical engineering to simulate the placement of an auditory cue in a virtual 3D space (see binaural recording).
The sound localization mechanisms of the human auditory system have been extensively studied. The human auditory system uses several cues for sound source localization, including time- and level-differences between both ears, spectral information, timing analysis, correlation analysis, and pattern matching.
These cues are also used by animals, but there may be differences in usage, and there are also localization cues which are absent in the human auditory system, such as the effects of ear movements.
For determining the lateral input direction (left, front, right) the auditory system analyzes the following ear signal information:
Interaural time differences
Sound from the right side reaches the right ear earlier than the left ear. The auditory system evaluates interaural time differences from
Phase delays at low frequencies
group delays at high frequencies
Interaural level differences
Sound from the right side has a higher level at the right ear than at the left ear, because thehead shadows the left ear. These level differences are highly frequency dependent and they increase with increasing frequency.
For frequencies below 800 Hz, mainly interaural time differences are evaluated (phase delays), for frequencies above 1600 Hz mainly interaural level differences are evaluated. Between 800 Hz and 1600 Hz there is a transition zone, where both mechanisms play a role.
Evaluation for low frequencies
For frequencies below 800 Hz the dimensions of the head (ear distance 21.5 cm, corresponding to an interaural time delay of 625 µs), are smaller than the half wavelength of the sound waves. So the auditory system can determine phase delays between both ears very precisely. Interaural level difference are very low in this frequency range, so that a precise evaluation of the input direction is nearly impossible on the basis of level differences. As the frequency drops below 80 Hz it becomes difficult or impossible to use either time difference or level difference to determine a sound’s lateral source, because the phase difference between the ears becomes too small for a directional evaluation (i.e. the phase difference is great enough that the lagging wave sensed in the offside ear coincides with the next wave which is being sensed by the nearer ear).
Evaluation for high frequencies
For frequencies above 1600 Hz the dimensions of the head are greater than the length of the sound waves. An unambiguous determination of the input direction based on interaural phases is not possible at these frequencies. However, the interaural level differences become bigger, and these level differences are evaluated by the auditory system. Also, group delays between the ears can be evaluated; this is more pronounced at higher frequencies. This means, if there is a sound onset, the delay of this onset between both ears can be used to determine the input direction of the corresponding sound source. This mechanism becomes especially important in reverberant environment. After a sound onset there is a short time frame, where the direct sound reaches the ears, but not yet the reflected sound. The auditory system uses this short time frame for evaluating the sound source direction, and keeps this detected direction as long as reflections and reverberation prevent an unambiguous direction estimation.
The mechanisms described above cannot be used to differentiate between a sound source ahead of the hearer or behind the hearer; therefore additional cues have to be evaluated.
Sound localization in the median plane (front, above, back, below)
The human outer ear, i.e. the structures of the pinna and the external ear canal, form direction-selective filters. Depending on the sound input direction in the median plane, different filter resonances become active. These resonances implant direction-specific patterns into the frequency responses of the ears, which can be evaluated by the auditory system (directional bands). Together with other direction-selective reflections at the head, shoulders and torso, they form the outer ear transfer functions.
These patterns in the ear’s frequency responses are highly individual, depending on the shape and size of the outer ear. If sound is presented through headphones, and has been recorded via another head with different-shaped outer ear surfaces, the directional patterns differ from the listener’s own, and problems will appear when trying to evaluate directions in the median plane with these foreign ears. As a consequence, front–back permutations or inside-the-head-localization can appear when listening to dummy head recordings,or otherwise referred to as binaural recordings.
Distance of the sound source
The human auditory system has only limited possibilities to determine the distance of a sound source. In the close-up-range there are some indications for distance determination, such as extreme level differences (e.g. when whispering into one ear) or specific pinna resonances in the close-up range.
The auditory system uses these clues to estimate the distance to a sound source:
Sound spectrum : High frequencies are more quickly damped by the air than low frequencies. Therefore a distant sound source sounds more muffled than a close one, because the high frequencies are attenuated. For sound with a known spectrum (e.g. speech) the distance can be estimated roughly with the help of the perceived sound.
Loudness: Distant sound sources have a lower loudness than close ones. This aspect can be evaluated especially for well-known sound sources (e.g. known speakers).
Movement: Similar to the visual system there is also the phenomenon of motion parallax in acoustical perception. For a moving listener nearby sound sources are passing faster than distant sound sources.
Reflections: In enclosed rooms two types of sound are arriving at a listener: The direct sound arrives at the listener’s ears without being reflected at a wall. Reflected sound has been reflected at least one time at a wall before arriving at the listener. The ratio between direct sound and reflected sound can give an indication about the distance of the sound source.
Signal processing
Sound processing of the human auditory system is performed in so-called critical bands. Thehearing range is segmented into 24 critical bands, each with a width of 1 Bark or 100 Mel. For a directional analysis the signals inside the critical band are analyzed together.
The auditory system can extract the sound of a desired sound source out of interfering noise. So the auditory system can concentrate on only one speaker if other speakers are also talking (the cocktail party effect). With the help of the cocktail party effect sound from interfering directions is perceived attenuated compared to the sound from the desired direction. The auditory system can increase thesignal-to-noise ratio by up to 15 dB, which means that interfering sound is perceived to be attenuated to half (or less) of its actual loudness.
Localization in enclosed rooms
In enclosed rooms not only the direct sound from a sound source is arriving at the listener’s ears, but also sound which has been reflected at the walls. The auditory system analyses only the direct sound[citation needed], which is arriving first, for sound localization, but not the reflected sound, which is arriving later (law of the first wave front). So sound localization remains possible even in an echoic environment. This echo cancellation occurs in the Dorsal Nucleus of the Lateral Lemniscus(DNLL).
In order to determine the time periods, where the direct sound prevails and which can be used for directional evaluation, the auditory system analyzes loudness changes in different critical bands and also the stability of the perceived direction. If there is a strong attack of the loudness in several critical bands and if the perceived direction is stable, this attack is in all probability caused by the direct sound of a sound source, which is entering newly or which is changing its signal characteristics. This short time period is used by the auditory system for directional and loudness analysis of this sound. When reflections arrive a little bit later, they do not enhance the loudness inside the critical bands in such a strong way, but the directional cues become unstable, because there is a mix of sound of several reflection directions. As a result no new directional analysis is triggered by the auditory system.
This first detected direction from the direct sound is taken as the found sound source direction, until other strong loudness attacks, combined with stable directional information, indicate that a new directional analysis is possible. (see Franssen effect) |
Zaslal: Št november 17, 2016 11:25:49 Predmet: |
Blbý preklad v google ale len pre zaujímavosť:
Interaural časové rozdiely:
zvuk z pravej strany dosiahne pravé ucho skôr ako na ľavé ucho. Sluchový systém vyhodnocuje interaural časové rozdiely od:
Fázové oneskorenie pri nízkych frekvenciách
skupinové oneskorenie pri vysokých frekvenciách
Interaural rozdiely úrovne:
zvuk z pravej strany má vyššiu úroveň v pravom uchu, než na ľavom uchu, pretože https://en.wikipedia.org/wiki/Head_shadow na ľavé ucho. Tieto rozdiely úrovne sú vysoko závislé na frekvencii a zvyšujú so zvyšujúcou sa frekvenciou.
Pre frekvenciách pod 800 Hz, a to predovšetkým interaural časové rozdiely sú hodnotené ( fázové oneskorenie ), pre frekvencie nad 1600 Hz hlavne interaural úrovni rozdiely sú hodnotené. Medzi 800 Hz a 1600 Hz je prechodová zóna, kde obaja mechanizmy hrajú úlohu.
Velmi zaujímavé hlavne pre mna.  |
Zaslal: Št november 17, 2016 11:34:31 Predmet: |
Podle mě dolní mez 25-30Hz stačí bohatě, zejména, pokud nemáš speciálně upravenou poslechovku (kmitající panely .... ).
K tomu textu o lokalizaci, jo je to zajímavé, nicméně dobře známé, možná by stačilo místo dlouhatánského copy + paste dát odkaz na původní článek. _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: Št november 17, 2016 11:35:16 Predmet: |
Odpověď na otázku v titulku:
Jasně, bylo by fajn, kdybychom mohli poslouchat někde od 16 Hz, ale málokdy na to stačí peněženka a zejména poslechový prostor.
Takže bych opáčil jinou otázkou:
Kdo z nás má to štěstí, že může poslouchat už od 25 Hz ?
Řekl bych, že většina dostupných beden začíná okolo 40-50 Hz.
Mám tedy na mysli zlom, odkud začíná bedna padat. Samozřejmě, pokud budeme měnit kritérium mezního kmitočtu, tak v závislosti na povoleném poklesu (-3dB, -6dB, -20dB) dostáváme rozdílné výsledky. _________________ Cui bono ? |
Zaslal: Št november 17, 2016 11:52:44 Predmet: |
| PMA napísal: | Podle mě dolní mez 25-30Hz stačí bohatě, zejména, pokud nemáš speciálně upravenou poslechovku (kmitající panely .... ).
K tomu textu o lokalizaci, jo je to zajímavé, nicméně dobře známé, možná by stačilo místo dlouhatánského copy + paste dát odkaz na původní článek. |
PMA tu je , aj foto hifi systému čo ma zaujal:
http://digitalroomcorrection.hk/2014/12/
http://digitalroomcorrection.hk/category/speakers/
Zaslal: Št november 17, 2016 13:17:13 Predmet: |
Moc pěkný bedny. Jestli je to pro Tebe dostupné, určitě budeš spokojen.  _________________ Cui bono ? |
Kocour Hifista - zaslúžilec
Zaslal: Št november 17, 2016 13:27:59 Predmet: |
Myslim ze je delal Shinobiwan z diyaudio. _________________ HTPC + RME ADI-2 DAC + Yamaha M-50Dawsoo + ruzne DIY repro |
Machalik Hifi expert
Založený: 15 január 2007 Príspevky: 1627
Zaslal: Št november 17, 2016 13:29:12 Predmet: |
| Kopie Rockportu. |
MaG Hifi expert
Zaslal: Št november 17, 2016 15:01:35 Predmet: |
Na tému stereofónie, lokalizácie... sa tu už v minulosti diskutovalo:
http://hifi.slovanet.sk/bb/viewtopic.php?t=690
Pokiaľ ide o najnižšie frekvencie, je to podľa mňa vec osobných preferencií, preto všeobecná zhoda tu nikdy nenastane.
Jeden by chcel do "obývačky" preniesť zvuk koncertnej sály aj s intenzitou a frekvenčným rozsahom živého koncertu, druhý chce, aby mu to hralo ako v "obývačke". Aj skutočný kontrabas bude hrať v akustike obývačky inak, ako v koncertnej sále. A aj v koncertnej sále záleží na tom, či bude hrať čisto akusticky, alebo cez PA reprodukčný reťazec.
Uviesť pri hudobných nástrojoch len frekvencie tiež ešte o ničom nevypovedá, chcelo by to poznať aj ich intenzitu a štruktúru. Môžu to byť len nižšie harmonické s veľmi nízkou intenzitou.
Ja osobne preferujem "relaxačný" posluch pri strednej, až nižšej hlasitosti. Hi-Fi u mňa znamená, že to má hrať čisto a detailne. Napr. pri kontrabase chcem počuť jednotlivé tóny, ale vyslovene nechcem nejaké "chvenie nábytku", či "masírovanie bránice".
Ale chápem, že niekto iný má úplne iné preferencie. |
termit Nádejný hifista
Založený: 11 júl 2009 Príspevky: 70
Zaslal: Št november 17, 2016 15:29:04 Predmet: Re: Stačí Nám reprosustava aby hrala cca od 25-30 Hz ? |
| BlackBerry napísal: | | Graf ako su nástroje frekvenčne. |
David Popper, Elfentanz op.39; takty 38-50, napríklad.
[/img]http://s3-eu-west-1.amazonaws.com/ireland.images.shop/592/186592_zoom-05.png[img]
Slovami: tá pasáž prebieha od h3 cez d4 (!) späť do fis2.
Podľa tabuliek d4=2348,3Hz.
Tak to vyzerá, že buď má niekde chybu autor, alebo všetci cellisti, čo to kedy hrali, hrajú a budú hrať, alebo tabuľky...
Mimochodom, i keby nakrásne rozsah violoncella bol naozaj len do toho c3, i tak vzniká prinajmenšom odôvodnené podozrenie, či náhodou nielen kvalita toho-ktorého daného nástroja, ale i kvalita hráča na ten nástroj nie je dávaná i schopnosťou "vybudiť" alikvotné tóny, inak takto nižšími a vyššími harmonickými zvané...[/img] |
Zaslal: Št november 17, 2016 15:34:09 Predmet: |
V těch tabulkách jsou chyby.
Nejníž jdou (podle konstrukce), varhany, až k 16Hz. Přesto vidím na doma 25 Hz jako OK. Pokryje to klavír.
... nižší harmonické (subharmonické) snad ne, alikvotní tóny jsou snad jen vyšší harmonické? _________________ mám rád hifi, ale víte, jak je to dál .....
Naposledy upravil PMA dňa Št november 17, 2016 16:03:18, celkom upravené 2 krát. |
tatko Tom Hifi inventar
Založený: 21 február 2016 Príspevky: 3296 Bydlisko: Prievidza
Zaslal: Št november 17, 2016 15:34:55 Predmet: |
Hmmm
Dá sa vôbec reálne vyžiariť a počuť (cítiť) v obývačke 5x4 zvuk pod napríklad 30 Hz?
A za akú cenu? _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
Zaslal: Št november 17, 2016 15:35:53 Predmet: |
| tatko Tom napísal: | Hmmm
A za akú cenu? |
Za cenu problémů  _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: Št november 17, 2016 18:16:51 Predmet: |
| PMA napísal: | V těch tabulkách jsou chyby.
... nižší harmonické (subharmonické) snad ne, alikvotní tóny jsou snad jen vyšší harmonické? |
Ano, omlouvám se. Pokud si vůbec něco správně pamatuji ze školy, pak ano, z hlediska čistě fyzikálně-matematického jsou alikvotní tóny asi jen vyšší harmonické. Předtím mi trochu ujela ruka - podvědomě jsem bral do úvahy praxi, kdy při rozezvučení jednoho tónu se často rozechvěje i nižší struna se všemy "důsledky". Smyslem ale bylo jen zkusit potichu vyslovit, že "spoléhání" na tabulkové hodnoty všelikých rozsahů hud.nástrojů (a snad i reprobeden?) může být vachrlaté. Bůhví, co všechno a jak slyšíme ...  |
Zaslal: Št november 17, 2016 18:24:43 Predmet: |
| Mam ted doma Quadral Titan Mk V a je to cajk :) Nizke frekvence jsou prijemne. |
Zaslal: Št november 17, 2016 18:33:11 Predmet: |
| termit napísal: |
Rozumím a souhlasím, věrně to domů, bohužel, nedostaneme, a to ani jeden jediný nástroj, třeba zcela namátkou - cello
Tedy vlastně jo, pokud ho máme doma!  _________________ mám rád hifi, ale víte, jak je to dál ..... |
JHradec Hifista - zaslúžilec
Zaslal: Pi november 18, 2016 11:09:44 Predmet: |
Dělal jsem před léty takový experiment ( podobný aprílovému z Hudby a Zvuku). 15" Tannoy namontovaný do "dveří" mezi místnostma.
Takže poslechovka cca130 kubíků- bedna cca40 kubíků( vně poslechovky ).
Rezonanční kmitočet to mělo 18 Hz.Kmitočty od 22 Hz níže jsem vnímal už jako jednotlivé rázy. Zvuk byl impozantní i když mono. Prakticky jsem ověřil, že takové řešení má záporný VAF . |
Zaslal: Pi november 18, 2016 14:24:15 Predmet: |
Mal som v obývačke nejaký čas jednu Tesla AKR153.
Možno pre to, že izba nieje uzavretá - je z nej otvor do ďalších priestorov zhruba 1x2,5 metra - z tej opachy liezlo aj pod 20Hz... Stála pri ňom.
Iste so značným poklesom no stále láka ako doplniť terajšie veľmi dobré stĺpovky o zvuk povedzme 16-30 Hz
Samozrejme miestnosť (zhruba 5,5x4 metre) spôsobuje značnú nerovnomernosť hlasitosti a veľký zmysel to nemá (nielen kvôli nákladom), no láka... _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
Zaslal: Pi november 18, 2016 14:46:01 Predmet: |
| PMA napísal: | ... věrně to domů, bohužel, nedostaneme, a to ani jeden jediný nástroj, třeba zcela namátkou - cello
Tedy vlastně jo, pokud ho máme doma!  |
Přiznám se, že to jako laik nechápu. Domníval jsem se, že problém s reprodukcí hlubokých tónů nastává, když je vlnová délka větší než délka místnosti. Takže ten problém vzniká, jen když je zdrojem zvuku reprobedna, ale když je zdrojem zvuku hudební nástroj, tak tento problém není? Pokud budete mít čas a náladu vysvětlit to "jako pro blbce", budu rád. Díky ...  |
Zaslal: Pi november 18, 2016 14:59:48 Predmet: |
Aha, to je nedorozumnění, nemyslím zrovna nejnižší tón, hluboké tóny technicky v Hz. Myslím rekonstrukci zvukového pole, které vytvořil akustický nástroj (třeba zrovna to cello), pomocí cesty mikrofon(y) - záznam zvuku - reprodukce zvuku - zesilovač - reproduktor(y). Výsledek je větší nebo menší karikatura původního zvuku, ono to ani jinak být nemůže. _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: Pi november 18, 2016 15:31:09 Predmet: |
| Díky. Tím, že se jako hlavní problém probírala akustika poslechovky, jsem předpokládal problém až na akustické straně - tedy z bedny do cimry versus z nástroje do té samé cimry ... |
Zaslal: Pi november 18, 2016 15:35:22 Predmet: |
Aha, ale to je podle mě totéž. Když bude cello hrát v cimře, tak ho nikdo v té cimře nenasnímá a nepřehraje z repro tak, aby to poslechově bylo stejné z repro, jako bylo to samotné cello. Prostě to nikdo neumí. "Věrná reprodukce" je čistá iluze. _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: Pi november 18, 2016 15:44:14 Predmet: |
| Nechápem prečo sa hifisti tak ženú za vernou reprodukciou. Veď ľudský mozog, aby mal zážitok z hudby, mám na mysli emóciu znej dokáže prijať aj bez vernej reprodukcie. Vie si domyslieť napr. bas teda predstaviť aj keď ho reálny nepočuje. |
jean Hifista
Založený: 18 apríl 2007 Príspevky: 172 Bydlisko: Nitra - Cabaj
Zaslal: Pi november 18, 2016 15:57:24 Predmet: |
| Homer, no šak si to napísal, oni nepotrebujú zážitok z hudby, ale ten pocit, "ako moc z konca hája to hrá". |
instant Nádejný hifista
Založený: 18 január 2016 Príspevky: 65 Bydlisko: Slovensko
Zaslal: Pi november 18, 2016 15:58:35 Predmet: |
| Homer: to je jak keby si mi povedal ze ked robim telocvik so zenou staci si domysliet ze to je Jessica Alba a secko je v poradku.. |
Zaslal: Pi november 18, 2016 16:06:49 Predmet: |
| Instant väčšina ľudi nepotrebuje resp. nepociťuje potrebu počuť hudbu čo najvernejšie realite vedia sa z nej tešiť aj z hocjakého šuntu. Možno aj viac ako hifisti z ich drahých či lacných zostáv. Jednoducho hudbu neriešia a vstrebávajú ju a tešia sa z nej. Hifi je podľa ´ňa úchylka. |
Zaslal: Pi november 18, 2016 16:10:35 Predmet: |
| PMA napísal: | | ... Když bude cello hrát v cimře, tak ho nikdo v té cimře nenasnímá a nepřehraje z repro tak, aby to poslechově bylo stejné z repro, jako bylo to samotné cello. ... |
Nenapadlo mě řešit variantu, že se někdo snaží vytvořit seriózní nahrávku doma v akusticky problematickém obýváku proto, aby pak tu problematičnost věrně reprodukoval. To podle mě nemá žádný praktický smysl.
Naopak snažit se doma v obýváku co nejlépe (ve smyslu co nejméně špatně) reprodukovat nahrávku pořízenou v kocerním sále, v nahrávacím studiu či v jiném vhodném "nahrávacím" prostoru, podle mě smysl má. Rozhodně se o to spousta lidí alespoň pokouší.
Taky si dokážu představit, že si někdo doma zahraje/zacvičí na cello. A asi si dokážu představit i to, že si z hraní doma udělá nějaký záznam. Že by ale ten záznam dělal s vidinou pořízení kvalitní nahrávky, se mi nezdá pravděpodobné.
To byl ten důvod, proč jsem ve vašem textu viděl porovnání domácí reprodukce "profi" nahrávky cella s domácím hraním na cello.
Ale pokud se oprostíme od toho, že jsem špatně pochopil obsah vašeho příspěvku - chápu správně to, že malý prostor nějakým způsobem limituje či jinak zásadně ovlivňuje hluboké tóny nezávisle na tom, zda se ty tóny linou z reprobeden nebo z přímo z hudebního nástroje?
Dík za trpělivost ...  |
Zaslal: Pi november 18, 2016 17:10:33 Predmet: |
| Homer Simpson napísal: | | Instant väčšina ľudi nepotrebuje resp. nepociťuje potrebu počuť hudbu čo najvernejšie realite vedia sa z nej tešiť aj z hocjakého šuntu. Možno aj viac ako hifisti z ich drahých či lacných zostáv. Jednoducho hudbu neriešia a vstrebávajú ju a tešia sa z nej. Hifi je podľa ´ňa úchylka. |
vacsina ludi si kupuje dietny salam v tescu.. a co s tym urobime? nic. a hlavne, nezacneme si ho tiez kupovat, lebo ved ostatnym to tiez staci, tak musi aj nam..
Rozdiel medzi hifistom a laikom je hlavne ten, ze hifista by mal racionalne vediet, za co dava peniaze, ked nakupuje techniku a nahravky. S pocitovanou radostou z hudby, znacky alebo neviemcoho, ani s cenovou kategoriou ktoru si ten ktory audiopacient moze dovolit, to nema nic spolocne.
btw, ked je podla teba hifi uchylka, naco marnis cas na hifi fore..? |
