Zaslal: Po marec 06, 2017 11:35:54 Predmet: Otravny vodoznak v streamovanej hudbe (posluchovy test) |
http://mattmontag.com/audio-listening-test/
| citácia: | | Digital audio watermarks hide extra information in an audio signal, usually for copyright enforcement purposes. The watermarks are designed to be inaudible, but necessarily add some distortion to the original audio. |
Naposledy upravil miero dňa Št september 13, 2018 07:57:53, celkom upravené 1 krát. |
Zaslal: St marec 08, 2017 09:33:34 Predmet: |
este clanok k tomuto a vysledky testu v odkaze hore
http://www.mattmontag.com/music/universals-audible-watermark
http://www.mattmontag.com/music/listening-test-results
| citácia: | | A while ago, I wrote about my confusion regarding Weird Spotify Compression Artifacts. It turns out the artifacts I was hearing are not due to compression, but a result of audio watermarks that Universal Music Group embeds in digitally distributed tracks. This watermark is embedded in UMG tracks on Rdio, Spotify, iTunes, Tidal, and others. The watermark can also be heard in Universal tracks broadcast over FM radio. Universal Music recordings make up about 25% of most online catalogs, and its labels include Interscope, The Island Def Jam, Universal Republic, Verve, GRP, Impulse!, Decca, Deutsche Grammophon, Geffen, etc. |
JHradec Hifista - zaslúžilec
Zaslal: Št september 13, 2018 08:35:17 Predmet: |
| nedělal jsem ABX, ale je to slyšet v té tišší části cca 3 s od začátku. na sluchátka z notebooku. V hlasitějším závěru jsem neregistroval nic. Pokud nebudu poslouchat soustředěně, klidně bych s tím dokázal žít. |
Zaslal: Št september 13, 2018 09:37:41 Predmet: |
Pridal som este nahravku Spotify normal kvality a original komprimovany do MP3 128kbps, MP3 V0, Vorbis q5 a Vorbis q9.
http://mr.ieero.com/pub/audio-watermark/
Kto si to stiahne, prezrie a vypocuje zrejme nieco veelmi zaujimave odhali...
Necham to tu par dni bez komentara. |
Lukaso Hifi obsluha
Založený: 15 január 2009 Príspevky: 22
Zaslal: St september 19, 2018 19:07:39 Predmet: |
Miero, díky, že jsi téma watermarkingu znovu vytáhnul a zveřejnil i soubory. Je to praktika, která mi opravdu na streamované hudbě vadí. Na souborech v ABX testu rozdíl slyším. S albama postiženýma vodoznakem jsem se setkal i u Tidalu (např. Hiromi - Voice). Nepříjemné je, že není předvídatelné, u kterých alb je vodoznak slyšet.
Ten rozdíl mezi Spotify normal a high je překvapivý. Doufám, že to je jen náhoda. |
Zaslal: St september 19, 2018 19:46:47 Predmet: |
Diky za reakciu!
Podla analyzy spektra rozdieloveho signalu mi pride, ze spotify-normal je (v tomto pripade) vorbis kodovany s parametrom q9 (320kbps).
Verzia spotify-high je divna, lebo sa mi nepodarilo najst parametre pre oggenc, ktore by dali podobne rozdielove spektrum (skusal som q10, 320, 320 managed). Takze odhadujem, ze v tom signale je okrem jasneho vodoznaku medzi 1-5kHz este nejaky dalsi (zrejme nepocutelny) vodoznak v celom spektre.
Chcelo by to zanalyzovat este dalsie tracky... |
