Papolius Hifi obsluha
Založený: 08 február 2011 Príspevky: 23
Zaslal: Po apríl 02, 2018 14:03:54 Predmet: Prodám McIntosh MC 2250 |
Pěkný stav, drobné vady na kráse. Originální manuál. 2x250W 8ohm
Měním sestavu. Cena 45000Kč
Při rychlém jednání možná sleva.
Praha, MStokr zavinac seznam.cz
ONO
0.02% maximum harmonic distortion at any power
level from 250 milliwatts to 500 watts from 20 Hz to
20,000 Hz.
INTERMODULATION DISTORTION
STEREO
0.02% maximum if instantaneous peak power output
is 500 watts or less per channel with both channels
operating for any combination of frequencies,
20 Hz to 20,000 Hz.
MONO
is 1000 watts or less for any combination of frequences,
20 Hz to 20,000 Hz.
FREQUENCY RESPONSE (at one watt output)
20 Hz to 20,000 Hz + 0 - 0.25 dB.
10 Hz to 100,000 Hz + 0.25 - 1 dB.
NOISE AND HUM
95 dB below rated output.
RATINGS
DAMPING FACTOR
Greater than 30
INPUT IMPEDANCE
50,000 ohms.
INPUT SENSITIVITY
Switchable: 0.75 volt or 2.5 volts—level control provided
for higher input voltages.
POWER GUARD
Clipping is prevented and THD does not exceed 2%
with up to 20 dB overdrive at 1 KHz.
GENERAL INFORMATION
POWER REQUIREMENTS
120 volts 50/60 Hz 0.7 to 12 amps.
SEMICONDUCTOR COMPLEMENT
76 silicon transistors
37 silicon rectifiers and diodes
9 integrated circuits
MECHANICAL INFORMATION
SIZE
Front panel measures 16 inches wide (40.7 cm) by
6-31/32 inches high (17.7 cm). Chassis measures
14-9/16 inches wide (37 cm) by 6-1/2 inches high (16.5
cm) by 14-1/2 inches deep (36.8 cm), including connectors.
Knob clearance required is 1 inch (2.5 cm) in
front of mounting panel
FINISH
Front panel is anodized gold. Chassis is chrome and
black
WEIGHT
80 pounds (36.3 kg) net, 94 pounds (42.6 kg) in shipping
carton
199.42 KB |
99 Time(s) |
208.32 KB |
118 Time(s) |
221.94 KB |
111 Time(s) |
Zaslal: Št apríl 12, 2018 16:18:55 Predmet: |
| Připomínám možnost rozumné domluvy na slevě...
Zaslal: Pi apríl 20, 2018 08:08:19 Predmet: |
| Cena snížena na 39500Kč nebo 1540 Euro.
Zaslal: Pi apríl 20, 2018 08:17:52 Predmet: |
