Založený: 08 september 2010 Príspevky: 9961 Bydlisko: Praha
Zaslal: Pi október 18, 2019 16:09:51 Predmet: Low-Distortion, Low-Noise Composite Operational Amplifier |
citácia: | A composite operational amplifier is presented that is optimized for building low frequency(<=100 kHz) signal paths with very low distortion and noise. It consists of a cascade of twomonolithic operational amplifiers and additional RC components for frequency compensation.The open-loop response is designed for conditional stability, such that a very large gain-bandwidth product at signal frequencies can be achieved. This leads to very good distortionperformance in the audio frequency range. A numerical optimization procedure is introducedthat is used to derive the frequency compensation, based on specific stability criteria. MonteCarlo simulation results are presented that estimate the worst case deviation from the nominalstability margins. Measurement results confirm the predicted high gain-bandwidth product (10GHz at 100 kHz) and excellent distortion performance (<−180 dB). Furthermore applicationnotes considering various implementation issues such as large-signal stability are given. Ap-plications for the new composite operational amplifier include, e.g., audio frequency distortionmeasurement equipment. |
Viac: https://pdfs.semanticscholar.org/b96c/62efa54d464b7fbb7c5bf61906e3cbb9b830.pdf |
Založený: 24 február 2007 Príspevky: 10811 Bydlisko: Praha
Zaslal: So október 19, 2019 12:55:12 Predmet: |
Dík za odkaz. Pánové udělali skvělou práci. Jediné, co mi trochu dělá vrásky, je metodika měření THD -180 dB. Použili ten známý trik, že obvod pracuje se zesílením 60 dB, takže naměří čistých 120 dB a těch 60 k tomu přičtou. Ono to nějak funguje, dělají to i velcí výrobci operačních zesilovačů, ale podle mého to není tak docela košer. To už bych raději viděl nějaký super vypiplaný notch filter, ale tam by narazili mnohem dřív na šum. V reálu na -180 dB budou zlobit i odpory, o kondenzátorech a šumu nemluvně. _________________ Cui bono ? |
tatko Tom Hifi expert
Založený: 21 február 2016 Príspevky: 1963 Bydlisko: Prievidza
Zaslal: So október 19, 2019 16:38:34 Predmet: |
-100 dB a viac - o čom??? _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, FiiO E09K QOGIR + FiiO E07K ANDES, Stĺpové dvojpásmo (appolito) s 2x PSB600-1 + DT300 vo WG300 made in "TLU"
Založený: 18 január 2007 Príspevky: 19764
Zaslal: So október 19, 2019 18:10:51 Predmet: |
tatko Tom napísal: | -100 dB a viac - o čom??? |
Presne tatko, pro zvuk bezcenne udaje. Dobre pro techno honeni trika. _________________ Dispre2-JFET preamp, Z-30_2020 power amp, CNO-T25 repro |
Zaslal: So október 19, 2019 22:44:01 Predmet: |
Nemyslím si, že by kdokoliv předpokládal, že ten obvod použije na poslouchání muziky. Ale jako posouvání hranic možného v měřicí technice to význam má.
Jenom by to nejdřív chtělo spolehlivou metodiku měření pro úrovně pod -140 dB a pak to změřit při jednotkovém zisku. To by bylo jiný kafe. _________________ Cui bono ? |
Založený: 06 október 2006 Príspevky: 5274 Bydlisko: Trnava
Zaslal: Ne október 20, 2019 05:51:50 Predmet: |
Však je to tam napísané..
citácia: | Applications for the new composite operational amplifier include, e.g., audio frequency distortionmeasurement equipment. |
Aj meranie je "honenie trika"?  |
Založený: 06 október 2006 Príspevky: 4756 Bydlisko: Plzeň
Zaslal: Ne október 20, 2019 17:35:13 Predmet: |
opa napísal: |
Jenom by to nejdřív chtělo spolehlivou metodiku měření pro úrovně pod -140 dB a pak to změřit při jednotkovém zisku. To by bylo jiný kafe. |
To přijde. Je něco jiného spolehlivě kompenzovat zkreslení na -145dB z -110dB a z -135dB - posun fáze o zlomek stupně udělá v obou případech diametrální rozdíl. Je vždycky dobré mít základní zkreslení co nejnižší. Operáky s nízkým zkreslením jsou velice užitečné, ale samozřejmě není řeč o poslechu, ale o měření.
Mně by se třeba velice hodil diferenciální/přístrojový operák s minimálním zkreslením, kterým by šel udělat spolehlivě nezkreslující symetrický vstup předřazený před zkompenzovaný SE vstup. Kompenzace symetrického vstupu se signálem v obou větvích je daleko komplikovanější. |
Zaslal: Ne október 20, 2019 18:13:12 Predmet: |
Díky za tip. OPA1622 (tedy 1611) mi výrazně snížil zkreslení výstupu zvukovky, TI jde dobrým směrem. Přiznám se, že bych rád hotový přístrojový operák, nechce se mi řešit přesné odpory. Ale budu to potřebovat až za nějakou dobu, možná už budou nové obvody s ještě lepšími parametry. Ceny nových čipů se poslední dobou také zlepšují, údajně mají novou linku na větší wafery. |
Zaslal: Ne október 20, 2019 19:01:53 Predmet: |
Presnosť odporov nebude mať vplyv na skreslenie, len na CMR. |
Zaslal: Ne október 20, 2019 20:18:25 Predmet: |
Jasně. V tomto případě by ale CMR bylo také podstatné, protože by se jednalo o standardní měřicí vstup, u kterého by se slušné CMRR očekávalo/potřebovalo. Ale to je ještě tak daleko (pokud na to vůbec dojde), že si opravdu myslím, že se stávajícím tempem vývoje nových operáků budou k dispozici i špičkové přístrojové operáky s obdobným zkreslením. Když už mají vyvinutý funkční layout pro operák, umístit je do přístrojáku možná nebude tak složité/drahé na vývoj. Uvidíme... |
Zaslal: Ne október 20, 2019 21:58:17 Predmet: |
Kombinace s přesnými odpory na jednom čipu nemusí být triviální. Čtyři přesné odpory jsou sranda a vůbec bych se nestyděl koupit 0,1 % , proměřit je a zbytek doladit jedním pevným odporem. Stačí dodržet poměr R1/R2=R3/R4. _________________ Cui bono ? |
