Advice regarding installing solar panel system
artista
Založený: 12 marec 2021
PríspevokZaslal: Pi marec 12, 2021 18:25:56    Predmet: Advice regarding installing solar panel system Odpovedať s citátom
Hello everyone!
I'm not sure if I am writing in the best thread but does anyone have any experience with solar panels?
My family is considering to install solar panel in New Jersey with a loan. What is the most general tip on the matter?
So I'd very appreciate any good advice on this solar panels that I have to read about solar panel system.
Thank you so much for your advice!
bluemilk
Založený: 17 marec 2021
PríspevokZaslal: St marec 17, 2021 20:19:02    Predmet: Odpovedať s citátom
It's really worth it. However, I can give you a good advice. Contact some reliable company that help you calculate the efficiency of your solar system. You can also use this solar calculator, check this out. You are less likely to make a mistake in this way. Good luck!
DylanJorgensen
Ready2Die
Ready2Die
Založený: 27 december 2022
PríspevokZaslal: Ut december 27, 2022 18:19:16    Predmet: Odpovedať s citátom
Solar panels can be repaired. In fact, most solar panels are designed to be repaired. The cost of repairing a solar panel is almost exactly the same as replacing it so you can buy best off grid solar system packages to save some money. If you want to replace your solar panel, you will usually have to replace all the other parts in the system as well.
