platon.rado Hifista
Založený: 03 november 2008 Príspevky: 169 Bydlisko: Banská Bystrica
Zaslal: St jún 30, 2021 09:10:44 Predmet: Cambridge Audio DacMagic |
100% funkčný.
Techn.info.
D/A converters Dual Wolfson WM8740 24bit DACs
Digital filter Texas Instruments TMS 320VC5501 DSP
upsampling to 24bit 192kHz
Analogue filter 2-Pole Dual Differential Bessel Double Virtual
Earth Balanced
Frequency response 20Hz to 20kHz (±0.1dB)*
THD @ 1kHz 0dBFs <0.001% 24bit
THD @ 1kHz -10dBFs <0.001%
THD @ 20kHz 0dBFs <0.002%
S/N ratio -112dBr
Total correlated jitter <130pS
Crosstalk @ 1kHz < -100dB
Crosstalk @ 20kHz < -90dB
Output impedance <50ohms
Output level (unbalanced) 2.1V rms
Output level (balanced) 4.2V rms (2.1V per phase)
Digital input word widths supported 16-24bit**
Digital input sampling frequencies supported 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz
Audio output upsampling Fixed 24bit 192kHz
Dimensions (H x W x D) 52 x 215 x 191mm
(2.0 x 8.6 x 7.6”)
Weight 1.2kg/2.6lbs
Cena 90€ |
ravenman Hifista - zaslúžilec
Založený: 28 február 2009 Príspevky: 890 Bydlisko: Martin
Zaslal: St jún 30, 2021 18:51:32 Predmet: |
| Zdravím, je k tomu napájací adaptér a krabica? |
platon.rado Hifista
Zaslal: St jún 30, 2021 20:30:35 Predmet: |
| Krabica nie... adaptér áno. |
platon.rado Hifista
Zaslal: Ne júl 04, 2021 10:04:04 Predmet: |
| Predané |
