Simulating crossover filters with VituixCAD and EQ APO
PríspevokZaslal: Pi marec 01, 2024 22:51:52    Predmet: Simulating crossover filters with VituixCAD and EQ APO Odpovedať s citátom
Asi najpohodlnejsi prenos filtrov z VituixCADu priamo do softverovu ekvalizera:
Ever wanted to listen to your passive filter design and make sure you haven't make any obvious errors before purchasing components and spending the time assembling a crossover? Well now you can! The attached instruction is a simple step by step to export filter transfer functions from VituixCAD as impulse response, which can be loaded into EQ APO using "convolution with impulse response". Following this easy process, any filter transfer function that you can create with VituixCAD can be imported into EQ APO as a digital filter and heard instantaneously.
This information was recently provided by Kimmo over at DIYAudio, I've simply compiled it into a basic step by step instruction.
Zdroj: https://diy.midwestaudio.club/discussion/1832/simulating-crossover-filters-with-vituixcad-and-eq-apo
PríspevokZaslal: So marec 02, 2024 11:52:40    Predmet: Odpovedať s citátom
Vyexportovana impulzna odozva obsahuje vsetky digitalne filtre (vratane utlmov a delayu) a tiez pasivne suciastky.
Tzn. co v impulznej odozve nechcem, je treba vypnut (napr. mam predradeny utlm na vyskovom drivere).
PríspevokZaslal: So marec 02, 2024 14:49:08    Predmet: Odpovedať s citátom
Jak je dlouhá?
PríspevokZaslal: Ne marec 03, 2024 22:59:03    Predmet: Odpovedať s citátom
Podla toho kolko "taps" sa nastavi pri exporte. Napriklad pre 96kHz a 32768 taps je to 0,34s. Nastavit to ide najviac na 131072 a najmenej na 128 taps.
S MiniDSP by sa to muselo obmedzit asi na 1024, ten to ma podporovane takto:
The miniDSP Flex Eight can compute a total of 4096 taps. These can be distributed as you wish across the two input channels, with the limitation that each channel must have 6 or more taps and can have no more than 2048 taps.
Zdroj: https://docs.minidsp.com/product-manuals/flex-eight/dsp-reference/fir-filtering.html#enabling-and-disabling-the-filter
