FS: High quality PCB board for amplifier power supply
audio_holic
Založený: 15 august 2011
PríspevokZaslal: Ut december 04, 2012 12:48:04    Predmet: FS: High quality PCB board for amplifier power supply Odpovedať s citátom
Due canceled project, I have a larger quantity of high quality bare PCB amplifier power supply boards available. Dimensions are 83x108 mm. 105 um thick copper traces. It supports dual rectification per channel, optional snubber filter, CRC filter. Maximum capacitor diameter is 30 mm.
Price for board is 10 EUR + post costs.
Email: moonaudio (at) gmail.com
 Filesize:  147.88 KB
 Viewed:  226 Time(s)
PríspevokZaslal: Ut december 04, 2012 13:38:19    Predmet: Odpovedať s citátom
Would you mind posting schematics?
Thanks,
Pavel
audio_holic
PríspevokZaslal: Ut december 04, 2012 14:57:23    Predmet: Odpovedať s citátom
I don`t see a need for such a simple circuit like this. More important thing is ground laying, which in this case is done as it should be.
Some recommendations: Diodes D1-D8 should be TO 220 case diodes of your choose. I have a larger quantity of NXP (Philips) BYW29E-200 too. R1&R2 could be either short circuit or MPC71 0.22 ohm. Optional snubber circuit (R3-C5; R4-C6) consist of 1 ohm resistor MPC71 and 100 nF MKT cap.
audio_holic
PríspevokZaslal: Pi december 07, 2012 02:05:24    Predmet: Odpovedať s citátom
Bottom:
 Filesize:  97.75 KB
 Viewed:  184 Time(s)
audio_holic
PríspevokZaslal: St január 30, 2013 12:50:36    Predmet: Odpovedať s citátom
Still available...
audio_holic
PríspevokZaslal: Pi apríl 12, 2013 17:50:21    Predmet: Odpovedať s citátom
Few pcbs still left.
New reduced price: 6 EUR / each pcb
contact: moonaudio (at) gmail.com
audio_holic
PríspevokZaslal: Št máj 16, 2013 11:43:19    Predmet: Odpovedať s citátom
Still available...
