Bartoli Hifi inventar
Zaslal: Ut december 01, 2015 10:04:11 Predmet: |
Hehe kdyz uz probirame hifibahno tak ta historka s xavian XN 360 byla fakt poucna. Tehdy cca pred 10 lety sla od roba kolem tech scan speak sustitek v Brne takova propaganda ze je to top hifi a ze to stoji mraky penez a ze je to teda diky tomu superdobre. Moje dojmy z poslechu byly ale zcela opacne.
Ale koukam jmd pak stejne napise ze je to se sosakem pohodovy zvuk-)
Basstl Hifi expert
Zaslal: Ut december 01, 2015 10:16:35 Predmet: |
| Bartoli napísal: | Moje dojmy z poslechu byly ale zcela opacne. |
Jestli to nebude tím, že tvoje dojmy jsou skoro vždy opačné...
Zaslal: Ut december 01, 2015 10:45:30 Predmet: |
| Basstle tyhle rozdily jsou jen na okoposlech. Pri slepych testech by ty okorozdily zmizely a ty sosaky by vsichni splachli do zachodu-)
Zaslal: Ut december 01, 2015 10:56:37 Predmet: |
Dust cap vs Phase plug pohladom Seasu:
| citácia: | | The dust cap has great influence on the behaviour of a drive unit at high frequencies. We offer dust caps made from various paper qualities and from fabric. All of these may be coated for dynamic control. Dust caps made from Polypropylene, Aluminium and various PVC qualities are also available. Instead of the dust caps, we also offer phase plugs which eliminate the cavity inside the coil former, thereby lowering sound colouration. Since the phase plug improves the air circulation around the coil windings, the coil temperature variation as well as the consequent sensitivity modulation are lowered. Further, the power handling capacity is increased. |
Zdroj: http://www.seas.no/index.php?option=com_content&view=article&id=404&Itemid=268
Basstl Hifi expert
Zaslal: Ut december 01, 2015 11:03:44 Predmet: |
| Bartoli napísal: | | Basstle tyhle rozdily jsou jen na okoposlech. Pri slepych testech by ty okorozdily zmizely a ty sosaky by vsichni splachli do zachodu-) |
Já si to nemyslím.
XT 25/19 jsem slyšel hodněkrát a většinou se mi to líbilo. Je to to normální, běžná, slušně hrají kalota s malým zkreslením.
Taky Záleží kam to je. Když budu stavět malý budky do pracovny, nebo k PC, tak tam radši použiju tohle, než driver v horně.
Do hlavních beden bych radši dal ten driver.
Není potřeba to dramatizovat...
Zorg Hifi expert
Zaslal: Ut december 01, 2015 11:17:49 Predmet: |
Dobrý, to si řešte jinde. Třeba v "Blbé kaloty - tipy / triky"
Jelikož nevím, jaký mám udělat kalotě profil, tak nakonec asi zkusím udělat pokus (jestli mi to vyfrézujou), že fláknu ND25FN (tj. bez faceplate) jakoby mezi dvě zaoblení o poloměru cca. 75mm. Celé to bude na čelní stěně zabírat zhruba 7", hluboké to tedy bude 3". Uvidíme, jak se na to ta kalota bude tvářit
Zaslal: Ut december 01, 2015 11:45:04 Predmet: |
| Zorg napísal: | | Jelikož nevím, jaký mám udělat kalotě profil, tak nakonec asi zkusím udělat pokus... |
Však zkus nejdřív ten AxiDriver, zas tak složitý to není a nějaká standardní kalota jako příklad tam už bude taky předdefinovaná, stačí si to upravit.
Úplně nahoře to sedět nebude, ale základní představu to dá - minimálně o směrovém chování do cca 10 kHz IMO docela dobrou.
Zaslal: Pi október 14, 2016 12:10:32 Predmet: |
EG niekde pisal, ze reprobedna s OSWG pouzite ako center ma upravenu vyhybku aby vyzarovala na ose rovno. Ako sa vlastne nataca ten center, normalne na posluchaca?
Akurat v tom pripade uz asi neplati toto:
| citácia: | | Basically what one wants for good imaging is a pseudo point source response, i.e. a single direct sound free from any diffractions or reflections for at least 5, but hopefully a full 10 milliseconds. |
Zdroj: http://www.dagogo.com/an-interview-with-dr-earl-geddes-of-gedlee-llc
marcin Hifista - pokročilec
Založený: 30 september 2008 Príspevky: 374 Bydlisko: Pezinok
Zaslal: Pi december 02, 2016 22:26:38 Predmet: |
Máte niekto skúsenosti s hornami Dayton, konkrétne: http://www.daytonaudio.com/index.php/loudspeaker-components/loudspeaker-drivers-by-type/waveguides/h10rw-10-round-waveguide-1-threaded.html
Myslím, že MaBat, ty si mal 12'' verziu, ktorá sa už žiaľ nevyrába, 10'' za 8€/kus nie je čo riešiť na vyskúšanie.
Prípadne aký je váš názor na 10'' Dayton vs. 18sound XT1086: http://www.eighteensound.com/Products/Articles/Detail/catid/4063/eid/3353/xt1086
_________________ ......Casea Deneb, DRC Preamp, DPA 380, 2way OSSE WG, DSP PA2, NCore NC500, SW 15'' |
Zaslal: Pi december 02, 2016 22:42:00 Predmet: |
S tím 12" jsem kdysi dělal (viz obr.), ale chtělo to nějak opravit hrdlo. Ten 10" už bych dnes nepoužil, taky jsem to zkoušel, ten 18sound asi taky ne. Záleží, k čemu to má být - furt to bude lepší, než drátem do oka. Je to levný, to jo.
72.49 KB |
189 Time(s) |
174.14 KB |
183 Time(s) |
Zaslal: Pi december 02, 2016 23:03:45 Predmet: |
Dik za info
To hrdlo Dayton chce určite upraviť (mám ho už doma), ale vyzerá že by to nemal byť problém. Má to byť k tomuto:
Malé dvojpásmo ala Nathan, podporené ekvalizovaným 18'' subom, multisubs si nemôžem dovoliť kvôli priestoru.
Drivery, ktoré sa dostali do užšieho výberu:
http://www.eighteensound.com/Portals/0/PDFs/ND1018BT.PDF#page=1&zoom=auto,-130,842
http://www.eighteensound.com/Portals/0/PDFs/HD1040.PDF#page=1&zoom=auto,-130,842
10'' stredobas:
http://www.faitalpro.com/en/products/LF_Loudspeakers/product_details/index.php?id=151040110
http://www.bcspeakers.com/products/lf-driver/10-0/8/10nw64
http://www.rcf.it/en_US/products/precision-transducers/neodymium-low-frequency-transducers/mb10n251
datasheet k RCF ma byt tento: http://www.prodance.cz/data/attachments/en_MB10N251%20spec%20sheet.pdf
To RCF sa mi páči, ale dole mu chýba para. Ešte jedna dôležitá vec, 2-pásmo bude celé pasívne, aspoň zo začiatku.
